N/AC/AX Mixed Wireless Mode, “Maximizes performance”?
but now you are talking about ancient APs not ancient clients
We are talking about rare cases anyway. It can be old clients connected to old AP, but also old clients connected to modern AP with backwards compatibility. This AP understands the old clients and talks to them. Your router may not if some of the back compatibility was disabled by you.
We are also talking about as cheap as possible hardware home AIO router with bunch of settings found not working or doing nothing. N-only still listens for G. It allows N-only to connect, but not in greenfield mode. Disable B was found may not really disable B beacons (@sfx2000 on RT-AC68U tests I remember). Disable B was sticking in one firmware version with no reverse option except reset. Some IoTs were found have issues with disable B setting. Look at the first post - even Help pop-up in Asuswrt has bugs in it. The less you mess with this hardware the better. If someone is really after high performance this $50 home AP with somewhat working firmware and mostly BS marketing involved is not the right choice.
On RT-AX58U (running Merlin), for 5 GHz, it shows this list of choices/options:
Can it be set to AC/AX only?
The description box is outdated anyway and does not correspond to the choices/options in this menu:
AC/AX only isn’t an option there, so no.
Set it to N/AC/AX only if it makes you feel better. If your devices all support N or AC or AX, they’ll connect that way anyway. Using “Auto” (leaving A/N/AC/AX all active) won’t matter much unless you have devices you need to upgrade / replace anyway.
See, your devices only pause to share time while both devices try to transmit or receive at the same time. The good news is that even old A-only devices use OFDM, which as earlier posters said, plays nicer with other devices. Think of this as making A more “forward-compatible” than B, which doesn’t speak OFDM at all.
Your A-only device is more like a friend that speaks the same language and just talks slow. If they’re mostly quiet and reserved, they speak ODFM and can jump in for a word or two and then let the conversation continue. If they interrupt and talk a lot … well, unlike your friends, you can upgrade chatty slower devices with newer ones.
In contrast, a B-only device on 2.4Ghz is like someone suddenly screaming nearby in a different language (DSSS). They don’t even know how to say “is it my turn to speak?” in ODFM. If you disable B on your router, it won’t start up and encourage a whole separate conversation with someone in DSSS. That’s bad because it can only speak one language at a time, and the DSSS speaker can’t even tell when there’s a break long enough in the ODFM conversation to speak. If it wants to talk it yells in DSSS to ask for a turn (request-to-send or RTS) and the router has to interrupt everyone else and yell back an OK (clear-to-send or CTS), which slows everyone down even more. So disabling B on 2.4GHz, can have more effect than disabling A on 5GHz.
Keep in mind, preventing A devices (or on 2.4GHz, B devices!) from connecting to your network, doesn’t affect what your neighbors do. Part 15 FCC rules mean your device must play nice with nearby devices. Even if you disable A on your 5GHz network, your router’s radio will listen and try its best to allow conversations on the same channel (not just the same network), including conversations between your neighbor’s old A devices. The only way to get rid of that problem, is to find a 5GHz channel without any chatty A-only devices nearby, or gift your neighbor a new router you’ve secretly set to N/AC/AX only.
If you think “disabling A or N” will make your router yell over and ignore your neighbor’s A or N devices, it won’t. You can’t turn that off.
You control what devices you have and connect to your network, so the best way to not connect A devices to your network anymore, is … upgrade or replace them.
A/N/AC/AX/BE is much like...
G/N/AX/BE over in 2.4GHz land...
There's really no harm here once we get away from 11b legacy...
In current Router OS platforms - each connection is tracked by a CID based on the Association Request/Response handshakes when the client associates...
Back in the old days - community knowledge indicated that the slowest client defined the rate for everyone - that was 10 plus years ago.
That was an odd one - turning off 11b on the AC-68U basically broke wifi... I had a fix, but the issue here was the AIMesh stuff and how to manage that across different SDK versions...
Eventually my recommendation was to just remove that option for AsusWRT, as there was zero benefit and a lot of impact as things stopped working...
