!UPDATE in post #4
First of all, I wish a HAPPY NEW YEAR to all =)
I have a couple of strange entries in the syslog,
Thank you.
- Looks like my ext2 partition on the sub disk is mounted as ext4. Why is that happening?, is it a problem?, (and if yes,) how to solve it? (I already ran e2fsck, and checked with a PC too, no problems found)
- Transmission fails to set buffers , is that something I should worry about?
- what is that time disparity issue at the end?
Thank you.
Jan 1 01:00:10 kernel: scsi 0:0:0:0: Direct-Access TOSHIBA External USB 3.0 0001 PQ: 0 ANSI: 6
Jan 1 01:00:10 kernel: sd 0:0:0:0: [sda] 976773168 512-byte hardware sectors (500108 MB)
Jan 1 01:00:10 kernel: sd 0:0:0:0: [sda] Write Protect is off
Jan 1 01:00:10 kernel: sd 0:0:0:0: [sda] Assuming drive cache: write through
Jan 1 01:00:10 dnsmasq[296]: exiting on receipt of SIGTERM
Jan 1 01:00:10 dnsmasq[390]: started, version 2.67 cachesize 1500
Jan 1 01:00:10 dnsmasq[390]: compile time options: IPv6 GNU-getopt no-RTC no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth
Jan 1 01:00:10 dnsmasq[390]: warning: interface ppp1* does not currently exist
Jan 1 01:00:10 dnsmasq[390]: asynchronous logging enabled, queue limit is 5 messages
Jan 1 01:00:10 dnsmasq-dhcp[390]: DHCP, IP range 192.168.1.2 -- 192.168.1.7, lease time 7d
Jan 1 01:00:10 dnsmasq[390]: read /etc/hosts - 5 addresses
Jan 1 01:00:10 dnsmasq[390]: read /etc/hosts.dnsmasq - 0 addresses
Jan 1 01:00:10 dnsmasq-dhcp[390]: read /etc/ethers - 3 addresses
Jan 1 01:00:10 dnsmasq[390]: using nameserver 4.4.4.4#53
Jan 1 01:00:10 kernel: sda: sda1 sda2
Jan 1 01:00:10 kernel: sd 0:0:0:0: [sda] Attached SCSI disk
Jan 1 01:00:10 kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Jan 1 01:00:10 dnsmasq[390]: using nameserver 8.8.4.4#53
Jan 1 01:00:10 kernel: scsi 1:0:0:0: Direct-Access Multi Flash Reader 1.00 PQ: 0 ANSI: 0
Jan 1 01:00:10 kernel: sd 1:0:0:0: [sdb] Attached SCSI removable disk
Jan 1 01:00:10 kernel: sd 1:0:0:0: Attached scsi generic sg1 type 0
[B]Jan 1 01:00:10 hotplug[411]: USB /dev/sda1(ext4) failed to mount at the first try!
Jan 1 01:00:10 kernel: EXT2-fs warning: mounting unchecked fs, running e2fsck is recommended
Jan 1 01:00:10 hotplug[411]: USB ext4 fs at /dev/sda1 mounted on /tmp/mnt/sda1[/B]
Jan 1 01:00:11 rc_service: udhcpc 369:notify_rc stop_upnp
Jan 1 01:00:11 rc_service: udhcpc 369:notify_rc start_upnp
Jan 1 01:00:11 rc_service: udhcpc 369:notify_rc stop_ntpc
Jan 1 01:00:11 rc_service: udhcpc 369:notify_rc start_ntpc
Jan 1 01:00:11 dhcp client: bound [I]xxx.xxx.xxx.x[/I] via [I]xxx.xxx.xxx.xxx [/I]during 258472 seconds.
Jan 1 01:00:11 rc_service: hotplug 411:notify_rc restart_nasapps
Jan 1 01:00:11 FTP Server: daemon is stoped
Jan 1 01:00:13 WAN Connection: WAN was restored.
Jan 1 01:00:15 Samba Server: smb daemon is stoped
Jan 1 01:00:15 Samba Server: daemon is started
Jan 1 01:00:15 nmbd[494]: [2011/01/01 01:00:15, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan 1 01:00:15 nmbd[494]: Samba server RT-N66U is now a domain master browser for workgroup HOME on subnet UNICAST_SUBNET
Jan 1 01:00:21 admin: Started transmission-daemon from .
Jan 1 01:00:22 admin: Started znc from .
[B]Jan 1 01:00:22 transmission-daemon[516]: UDP Failed to set receive buffer: requested 4194304, got 233472 (tr-udp.c:78)
Jan 1 01:00:22 transmission-daemon[516]: UDP Failed to set send buffer: requested 1048576, got 233472 (tr-udp.c:89)[/B]
Jan 1 01:00:23 nmbd[494]: [2011/01/01 01:00:23, 0] nmbd/nmbd_become_dmb.c:become_domain_master_stage2(113)
Jan 1 01:00:23 nmbd[494]: Samba server RT-N66U is now a domain master browser for workgroup XXXX on subnet 192.168.1.1
Jan 1 01:00:38 nmbd[494]: [2011/01/01 01:00:38, 0] nmbd/nmbd_become_lmb.c:become_local_master_stage2(392)
Jan 1 01:00:38 nmbd[494]: Samba name server RT-N66U is now a local master browser for workgroup XXXX on subnet 192.168.1.1
Jan 1 12:45:49 rc_service: ntp 460:notify_rc restart_upnp
Jan 1 12:45:49 rc_service: ntp 460:notify_rc restart_diskmon
Jan 1 12:45:49 rc_service: waitting "restart_upnp" via ntp ...
Jan 1 12:45:49 disk monitor: be idle
[B]Jan 1 12:46:10 crond[311]: time disparity of 1578946 minutes detected[/B]
