questionesse
Hey there!
Not sure where to post this, since it relates to everything a bit, i'm thinking in building a home server, looking for a media streamer and also wifi/lan is needed. If this would fit somewhere else just shove it to there.
I'm having a really hard time deciding what to do. there are so many options out there and one seems to be better than the other
so here are my needs first of all
-I'm looking for a storage solution
more storage, not much, I guess 1TB would be enough for my needs
also a backup solution, as convenient as possible and incremental
also accessible on my network
-further on i'm looking for a solution to get my printer into the network, an old canon pixma ip 4000, my router is not interchangeable for one that supports that.
-I'd also like to stream my movies and music on my tv and on my stereo. just got an oldschool tv, no lcd or plasma, so no fancy hd things needed. but my tv and my hifi stand in two different corners of the room, so weather a wifi solution if applicaple and fast enough for that or a cable solution that is not loosing transfer quality over let's say 10meters.
and here are my first thoughts
I read about the xbox here as an NAS or media streamer solution, even if I didn't get all the tech details yet - can I combine both? can I add wifi to it?
If yes-
that would more or less everything except for the printer, and for that i could get a NAS adapter for it. Or am I missing a point here?
I thought about a NAS Raid housing like the ready nas duo,
but I'd still lack a backup solution, but a cheap usb external would do it.
but then I'd need the counterpart for receiving my media on tv or hifi
I thought about buying a media streamer that also works as a NAS with an option for a hard drive and an usb option for an external backup drive.
also here is no printer option as far as i know - or is there a device that has one?
the complete alternative would be building a home server out of my old desktop, with free NAS/Windows Home server, eventually exchanging some components for more energy efficient ones.
I like the idea and the flexibility, but i also fear to end up in a never finished project since i lack knowledge and a bit of time.
but i could host websites on it and everything, so this would be the real all in one solution which is upgradeable at all times
Here is what is waiting for potential usage:
-AMD athlon XP 2400+ dunno if this is useable for a home server
-GeForce4 Ti 4200 with passive cooling
-housing is a huge Cheiftec CS 601, but i have the room and it has plenty of HDD slots for nas, backup etc.
-power is supplied by a Seasonic S12-380 I guess I should get a more efficient one
-a 5.1 audio card from sound blaster as far as i remember so already a bit fit for audio
I really don't know what to do. you think i could get enough advice to try my own home server or would you recommend another solution for my needs? do you have specific ideas for the components in mind? let me know!
thanks a lot in advance - I'm curious as hell since i'm checking options for days now!
If yes-
