David Cavalli
Currently, I'm using an external Seagate (ext4 format) on my RT-AC68U router (Asuswrt-Merlin). The forum folks have helped me format this setup and maintain it. There's been an intermittent problem with the external HD as my main source for video, and the solution seems to be hardware based. When the drive gets in a bad state, core 1 goes 100% busy, the drive is invisible, and rebooting is the only solution.
Since I'm making my house even more dependent on that drive, the problem is happening more frequently and I'm looking to invest in a better solution. I use Plex / Sonarr on a Raspberry Pi (which works great), but thinking of putting them on a dedicated NAS, which can also store/serve the video data house-wide.
My main question revolves around which NAS to get, and I think the router will be the final point of the decision making process. The Synology DS218+ and DS718+ are the two models I'm considering. The 718 has dual ethernet ports and if I've read the forum right, I might be able to link aggregate them connected to the router. If so, that would be a great win! If not, the extra hardware on the 718 might not be worth the $100+ over the 218 model.
Will probably ask for help if/when I get either, but wanted to know if anyone had any particular experience and/or recommendations.
Also, if anyone has any feedback on the core 1 100% lock down issue (i.e. a way to software fix it, instead of reboot), that would make my wife happy.
Thanks!
Thanks!
