Native IPv6 - no LAN IP's populating
On the command line change "-P 64:b3040" to "-P 48:b3040" that change is what the "WAN Prefix Length" option it the gui sets.
killall odhcp6c
odhcp6c -df -R -s /tmp/dhcp6c -N none -c 0003000104d4c4bb3040 -P 48:b3040 -r23 -r24 -k ppp0
Still nothing :(
After you run the odhcp6c command, run:
Bash:
cat /tmp/wan*bound6.env
Results from running that command - IP REMOVED is the WAN IPv6 address
SSH_CLIENT=10.12.12.40 49868 2212
USER=Bruc3W4yn3
LD_LIBRARY_PATH=/lib:/usr/lib:/lib/aarch64
SHLVL=1
HOME=/root
SSH_TTY=/dev/pts/0
PS1=\u@\h:\w\$
LOGNAME=Bruc3W4yn3
TERM=xterm-256color
PATH=/bin:/usr/bin:/sbin:/usr/sbin:/home/Bruc3W4yn3:/mmc/sbin:/mmc/bin:/mmc/usr/sbin:/mmc/usr/bin:/opt/sbin:/opt/bin:/opt/usr/sbin:/opt/usr/bin
SHELL=/bin/sh
PWD=/tmp/home/root
SSH_CONNECTION=10.12.12.40 49868 10.12.12.12 2212
TMOUT=600
SERVER=
RDNSS=2a05:87c0:1::a
SNTP_IP=
NTP_IP=
NTP_FQDN=
SIP_IP=
DOMAINS=
SIP_DOMAIN=
AFTR=
CER=
OPTION_2=00030001ac7a56300f00
OPTION_1=0003000104d4c4bb3040
PREFIXES=
ADDRESSES=
RA_ADDRESSES=IP REMOVED/64,604798,2591998
RA_ROUTES=::/0,fe80::ae7a:56ff:fe30:f00,1798,512 IP REMOVED/64,,2591998,256
RA_DNS=
RA_DOMAINS=
RA_HOPLIMIT=64
RA_MTU=1492
RA_REACHABLE=0
RA_RETRANSMIT=0
PASSTHRU=001700102a0587c000010000000000000000000a
Doesn’t look that way, no.
I wonder if it’s something to do with the LAN prefixes they’ve assigned to me.
If I set Static IPv6 using the WAN prefix (/64) for both WAN and LAN, it works - but obviously assigns LAN devices IP’s from the WAN pool.
As soon as I set the LAN Prefix to be what it should be per my assignment on my account (/48) - then it breaks and no longer works.
Please run the odhcp6c command again, but also include -v first in the list of command line parameters and check the syslog afterward for messages from odhcp6c.
do I need to run the kill command first as well?
Yes. I might try:
killall odhcp6c
odhcp6c -v -df -R -s /tmp/dhcp6c -N try -c 0003000104d4c4bb3040 -P 0:b3040 -r23 -r24 -k ppp0
grep odhcp6c /tmp/syslog.log
cat /tmp/wan0_bound6.env
ip -6 addr show scope global
Yes. I might try:
killall odhcp6c
Command Line still shows no addresses etc. as per before.
Syslog shows:
This is an interesting wiki entry at OpenWrt (second paragraph):
Giganet​
Giganet are a CityFibre and BT Openreach fibre reseller. They provide IPv4 and IPv6 connectivity to business and residential customers. They provide a static IPv4 address and a static IPv6 router address, with a /48 prefix for the client's network.
DHCPv6 is used to IPv6 prefix delegation, but the IPv6 prefix must be released by the router before the prefix will be issued again to either the same router or to another router. If this doesn't happen, an error of NoPrefixAvail during DHCPv6 negotiation, and odhcpd will complain that there is a local route, but no prefix, so it doesn't issue IPv6addresses to LAN clients
So at least Enable “Release prefix on exit” and see if it helps. Not sure if it will release a prefix it hasn’t received lately. But worth a shot.
Ok I’ve enabled that and restarted the router. Still no LAN address/prefix populating.
If you kill odhcp6c again and reboot without any change, then you might want to contact the ISP and see if this claim is true that DHCPv6 Prefix Delegation won’t work if it was not previously released by the router.
From the gui set
Connection Type: Native IPv6
DHCP-PD: Enable
Accept Default Route: Disable
Release prefix on exit: Enable
WAN Prefix Length: 48
If that doesn't work try from SSH
killall odhcp6c
odhcp6c -v -df -R -s /tmp/dhcp6c -N none -c 0003000104d4c4bb3040 -P 48:b3040 -r23 -r24 ppp0
Have you ever tried changing the "Interface" type in the gui to something other than "PPP"? I don't expect it work, we have tried everything else, so why not. :rolleyes:
From the gui set
DHCP-PD: Enable
killall odhcp6c
On the WAN page?
My connection is a PPPoE connection so I don't think any other will work.
From the gui set
DHCP-PD: Enable
killall odhcp6c
No luck with anything there either.
To add to this - when my service was first installed and activated they installed their own ISP provided router, which is a Technicolor DGA4134.
IPv6 was enabled and working on that router, however there’s no option on it to “release” the prefix back, other than turning IPv6 off/disabled.
I tried cloning the MAC address of that router to my ASUS in case that did anything, but no luck with that either
Do I maybe need to check if they can see if the addresses are still allocated to that router perhaps? And if they can release manually or reassign me a new allocation of addresses?
