wsarahan
HI guys how are you?
I have a simple question but i would like your suggestion as i really in doubt what to do
I have teh RTAC5300 and a 350/150 Optic Fiber internet here
I have an Apple TV 4 , i use it wired but it`s very near the router, so, the Apple TV has only a 10/100 wired interface so using wired and doing a SpeedTest i get a speed 100/100 but it has an AC wireless adapter and i can get the 350/150 using wifi doiung the same test
SO considering that the wired connection is more reliable but there is a huge difference from speeds as i mentioned above what should i do? Use wired or wireless the Apple TV with the 5300 ?
Edit: Here as the Specs from Apple Tv 4 wireless and wired:
- Wi-Fi 802.11ac with MIMO
- Ethernet 10/100BASE-T
