Patrick9876
This thread is based on, and references, a couple other threads.
In the thread here I ask how set up sort of a WiFi extender containing an OpenVPN client so that the Ethernet-attached can see only the VPN, not the internet. And have this usable (with minor setup) with whatever WiFi network is available. The suggested (possible) solution was to try implementing it on a little GL.iNet portable router. Well, I'm trying, but have found I cannot even begin testing it. The problem is that the OpenVPN server is on my router - ASUS AX86U running Medlin - and so is my wireless access point.
In a thread asking about a similar testing problem here I was told (in post #3) why the configuration
I freely admit that I know nothing about DNAT so maybe the comment
Update:
From a little reading it sound like the DNAT table is created from port forwarding definitions. If That is true I have no idea what I would do to create the correct entry. The OpenVPN port is already exposed to WAN. Would I use the routers internal (LAN) IP address and the OpenVPN port? That doesn't feel useful to me.
My gut feeling (which is often wrong when it comes to routers) is that the packets requesting access to the OpenVPN port are probably not coming from the WAN; they're coming from the guest network's subnet ... which doesn't have access to my LAN.
a device connected to a guest network on my router and directing the OpenVPN connection to my DDNS url
can't work ... and that's the only config readily available to me (that I can think of) that would emulate target environment.I freely admit that I know nothing about DNAT so maybe the comment
may actually give the the solution. Maybe it would be helpful if someone explained (or pointed me to dox explaining) how to set that up in Merlin.I suspect the reason you can't establish the connection w/ #3 is because there is no DNAT rule in the nat table of the firewall to allow routing from the WAN's network interface to the LAN. That would normally be there *if* the OpenVPN server was located elsewhere inside the LAN. You would have had to establish a port forwarding for that purpose, which creates the DNAT rule in the PREROUTING chain of the nat table. Then forwarding is allowed by the "cstate DNAT" rule in the FORWARD chain of the filter table.
I suppose you could add a DNAT rule for these purposes
Update:
