Does the WNDR3700 support doing NAT for a subnet different than its own?
I have the following setup:
WNDR3700 - 192.168.1.1 255.255.255.0
Connected to it I have a DD-WRT loaded wrt54g. The linksys is connected from the lan port of the wndr3700 to the wan port of the wrt54g.
wrt54g wan ip - 192.168.1.2 255.255.255.0 gateway - 192.168.1.1
local ip - 192.168.2.1 255.255.255.0
The WRT54G has its firewall and NAT turned off.
I have a static route from the wndr3700 with the following
dest. ip 192.168.2.0
255.255.255.0
gateway - 192.168.1.2
I know that the routing is working because I can ping in both directions, and even manage the netgear from the 192.168.2.0/24 subnet. Also, I can ping yahoo.com, for example, from the WRT54G itself.
The WNDR3700 doesn't seem to be able to do NAT for clients on the linksys's subnet. Am I missing a setting? Can the the WNDR3700 do NAT for packets coming from the 192.168.2.0/24 subnet?
255.255.255.0
