mygiantcircle
Hi Tim and all:
I would like to ask for your kind help and input on the frustrating issue I encountered while setting up the DS1511+
Equipment:
Synology DS1511+
Dlink DIR-825 (first revision, firmware 1.01)
Issues:
After unboxing the newly purchased DS1511+ and followed the HD installation steps, I connected the NAS to the DIR-825. DS Assistant did not find the NAS on LAN. Next step was talking the NAS off LAN and direct connect it to my desktop PC. DS Assist found the NAS. I then set up the drives and installed DSM3.1. I thought I was home free. Nope.
Put the NAS back on LAN and DS Assist found the NAS for the most part (sometimes it does, sometimes it does not find it). Even when it does find the NAS, it would not able to logon 98% of the time (browser just keep on waiting for 192.168.0.xxx:5000). The time I was able to login, I cannot do anything because any task (say opening control panel) would just take very long or just hang.
Call tech support. They telnet into my PC in and check the NAS setting + PC setting - nothing unusual found. They were not able to login to the NAS while it was on LAN. They also inspected the debug.dat file. Nothing unusual found.
Checked the status of the DIR-825 - it sees the NAS. Set the static IP address for the NAS. Forwarded the ports. These tasks does not help.
So now I was stuck. What to do?
Then I remembered I had an old Linksys WRT54G router in the closet. Took that out and set up a small network consisting of just the WRT54G, PC, and NAS. The PC found the NAS! I was able to login! I could upload files. Things are snappy. I cried one drop of tear!
So now the finger points at the DIR-825. My questions are:
Is it something wrong with the DIR-825? Is there a diagnostic I can run to check the condition of the router?
Is it a setting on the router I need to change? Anything I can check (the wireless function works fine)?
Before I go off and have to buy another router, I hope you can help let me pin point if the issue is router hardware related.
Thank you!!
Dewey
Equipment:
Synology DS1511+
Issues:
Thank you!!
Dewey
