Donot remember the model but one is Seagate and the other is hitatch on USB 3 and 2 respectively. Is this relevant?What is the make and model number of both of the drives you are using?
Yes it's relevant because of the current draw of each device. For example, a typical 2.5" mechanical HDD needs ~900mA @ 5v to startup. A USB 3 socket can supply 900mA, but a USB 2 socket is only rated for 500mA. Also, the combined power requirements of each device (plus the router) shouldn't exceed the rating of the power supply.Donot remember the model but one is Seagate and the other is hitatch on USB 3 and 2 respectively. Is this relevant?
Good information to know. I think the two USB drives are Hitachi HTS727550A9E364 and Seagate FreeAgent GoFlex STAA1000101 on USB2 and USB 3 respectively. The Hitachi one does need 900mA for spinup but can not find relevant information of the Seagate...Yes it's relevant because of the current draw of each device. For example, a typical 2.5" mechanical HDD needs ~900mA @ 5v to startup. A USB 3 socket can supply 900mA, but a USB 2 socket is only rated for 500mA. Also, the combined power requirements of each device (plus the router) shouldn't exceed the rating of the power supply.
When power supplies get old the maximum current they supply can reduce slightly. If your current devices were already at the limit of what the router could supply it's possible that it can no longer do that.
The combined power requirements of two USB 3 devices might be an issue as theoretically you shouldn't be using the Hitachi in a USB 2 socket.Good information to know. I think the two USB drives are Hitachi HTS727550A9E364 and Seagate FreeAgent GoFlex STAA1000101 on USB2 and USB 3 respectively. The Hitachi one does need 900mA for spinup but can not find relevant information of the Seagate...
Why I should not be used Hitatchi on USB2, because that port doesnot provide enough power? Also I think I still experience the drive disappear issue with the Seagate on USB3. So I swapped seagate to USB2 and hitachi on USB3. Will see if that changes...Did not experience much difference on performance though...The combined power requirements of two USB 3 devices might be an issue as theoretically you shouldn't be using the Hitachi in a USB 2 socket.
Exactly. I don't know how strictly the Asus USB interfaces are implemented, but USB 2 is only rated for up to 500mA and the Hitachi requires 900mA to start up.Why I should not be used Hitatchi on USB2, because that port doesnot provide enough power?
Yes, I think I bought the drive and enclosure separately...But I have been using them for years and interesting to know the router has power issue...Exactly. I don't know how strictly the Asus USB interfaces are implemented, but USB 2 is only rated for up to 500mA and the Hitachi requires 900mA to start up.
EDIT: Is the Hitachi in some sort of caddy?
Welcome To SNBForums
