Need WiFi 6 router with native support for modifying it's DNS server config
Patrick9876
This is sort of a double (or triple) post but greatly simplified,
I need a router with WiFi 6 support that has the ability to add CNAME records to its DNS server. I assume (based completely on wishful thinking) that a router natively running OpenWrt or DD-WRT has a way for users to configure its DNS server. Am I dreaming? I know that the Merlin firmware for ASUS routers has this support - I'm using it right now - but I would rather be using a router running native firmware. I'm using my ASUS router (RT-AX86U) and the Merlin firmware on;y because of the support for DNS server customization. Otherwise, bit the router and firmware are overkill for my needs.
The recent more extensive posting is here.
Keep your AX86U and flash the Asus firmware. Get a Raspberry Pi (Pi 3b+ works well) and set up Pi-Hole. It has the ability to use CNAME. You can also use an old PC running Linux of some sort. Then set the Asus router to use the Pi-Hole (LAN-DHCP Server-DNS Server 1). Less than a $50 investment.
