Netflow
Just install softflowd via optware that's what I use to gather stats for NTOP
This may not be the best method as I'm not aware of an entware package for softflowd but this is the way I did it on my RT-N66U
Install Entware using the instructions on Merlin's WIKI;
https://github.com/RMerl/asuswrt-merlin/wiki/Entware
Download the attached file, unzip and copy softflowd_0.9.8-3_entware.ipk to your router
issue the command opkg install ./softflowd_0.9.8-3_entware.ipk
edit the file /opt/etc/init.d/S29softflowd and edit the following line to include the IP address and port of your netflow collector;
ARGS="-i br0 -n your_flow_collector_ip:port -m 16000"
e.g.
ARGS="-i br0 -n 192.168.9.68:2055 -m 16000"
  • softflowd.zip
I managed to get Netflow working on Entware using the package "ipcad". I'm not an expert, but here are simple install instructions I managed to google/piece together:
1. Install ipcad and libpcap (install command installed both for me)
opkg update
opkg install ipcad
2. Edit ipcad config (assuming server is at 192.168.1.200; commented lines left for completeness sake)
vim /tmp/mnt/sda1/asusware/etc/ipcad.conf
# interface ed0;
# interface ed1 promisc filter "ip and not dst net 192.168.0.0/16";
# interface sbni0 input-only netflow-disable; # Disable NetFlow.
# interface ppp*; # Dynamically pick up PPP interfaces.
# interface ulog group 3, group 15; # Use ULOG, do not disable NetFlow.
# interface ipq; # Use Linux IPQ (libipq(3))
# interface tee port 123; # Use BSD ipfw(8)'s tee.
# interface divert port 321 netflow-disable; # Use ipfw(8)'s divert(4).
interface eth0 promisc;
netflow export destination 192.168.1.200 2055;
# dumpfile = ipcad.dump;
# chroot = /adm/tmp;
# rsh enable at 127.0.0.1;
rsh disable
3. Test run (all on one line)
/tmp/mnt/sda1/asusware/bin/ipcad -c /tmp/mnt/sda1/asusware/etc/ipcad.conf -d
To manually stop, just "killall ipcad" as a ctrl-c doesn't seem to work.
Once working, you can add command(s) to startup script /jffs/scripts/services-start.
To test to see if the netflow is working, you can try using flow-capture/flow-cat or just install ntop or ntopng/nprobe.
e.g.
So I tried all this on my RT-N66U and I get the following whenever I try to start softflowd:
admin@RT-N66U:/tmp/mnt/usbdrive/entware/etc/init.d# /opt/etc/init.d/S29softflow stop
mkdir: can't create directory '/var/empty': File exists
Checking softflowd... dead.
admin@RT-N66U:/tmp/mnt/usbdrive/entware/etc/init.d# /opt/etc/init.d/S29softflow start
Starting softflowd... failed.
It seems it can't start for some reason. I have no idea why not. Any suggestions?
EDIT: I found a solution to solve this error.
So I manually ran "softflowd" and I noticed it was complaining:
admin@RT-N66U:/tmp/home/root# softflowd
softflowd: can't load library 'libpcap.so.1'
I know that libpcap was installed, so I looked on the usb drive in the entware/lib folder and saw the following files:
lrwxrwxrwx 1 admin root 14 Mar 11 00:39 libpcap.so -> libpcap.so.1.3
lrwxrwxrwx 1 admin root 16 Mar 11 00:39 libpcap.so.1.3 -> libpcap.so.1.3.0
-rw-r--r-- 1 admin root 229760 Feb 24 05:05 libpcap.so.1.3.0
I noticed there was no "libpcap.so.1" in the list, plus the first two files are just symbolic links to libpcap.so.1.3.0, so I made my own link:
ln -s libpcap.so.1.3.0 libpcap.so.1
Then I tried to start the service again, and, SUCCESS!
admin@RT-N66U:/tmp/mnt/usbdrive/entware/lib# /opt/etc/init.d/S29softflow start
Starting softflowd... done.
Now to figure out why my collector isn't receiving any data....
Did you ever find out why your collector wasn't receiving data? I'm having the same issue. I can connect to ntop from the router via netcat successfully, but it seems softflowd isn't connecting for some reason.
I got ipcad to work. I am exporting eth0,1,2 and vlan2 but I only see one interface in the destination called Interface 65535.
Any idea how to achieve separate reporting for all 4 interfaces?
how did you get ipcad to work?
what steps/guide did you use?
@baeser basically what ckong mentioned above. I am running scrutinizer & prtg netflow v5 sensors.
of course you have to use the netflow sensor, not the sflow one.
