Dual-band (two radio) routers default to using high band for 5 GHz.So why Netgear say that "by default all Nighthawk Routers use high 5G band, i interpret that it applies to the both 5GHz bands".
"Tri-band" routers have three radios: 2.4 GHz; 5 GHz ch 36-48; 5 GHz ch 149-165.So on tri band one is for high and the second for low band, I thought Netgear meant on both 5GHz band. So you can not choose?
I wonder, why can't they just allow both of the 5GHz radios have full access to all available channels in the range. Any chance Netgeat will allow that so that people can choose which channels they want to use?
Tri-radio routers work because bandpass filters are used on each 5 GHz radio to keep them from overloading each other.Good question, but the problem is interference. If the radio is operating at full capacity, every channel is actually used. Your scenario would have every channel used twice, on the same board. This would wreak havoc on the network capability.
How so? What was the proof of interference?and even then as proved by the 3200 series there was some interference
I don't see what you are seeing.look at your own testing one the asus rt-ac3200 and its poor performance on 5 gig ,
Oki here it cost 2.500 SEK that more that a R7800 router cost (1.995 SEK) and a R8500 (2.499 SEK) so its quite expensive Extender/AP.
ok but how much is the orbi with 1 router and 1 sat ?
Welcome To SNBForums
