What is the maximum # of satellites that an AC3000 can handle?
What is the farthest you have been able to place a satellite from either the main unit or another satellite with a straight line of sight between them (if daisy chain is supported)?
Are the satellites that come with the AC3000 able to work with another one - i.e. - I get 2 AC3000 systems. Can I use the main router from one set and then both satellites from the 2 systems with it? It would leave me with only a main router left over but the deal I found for the RBK50 system makes it so it is cheaper to buy 2 sets than just one with an additional satellite.
