NETGEAR has released a late beta firmware for the R7500 that addresses some of the issues identified since the r7500 release. In particular some testers saw some issues in 5ghz range. These have been ADDRESSED along with some other early release elements. Feel free to download and install this latest firmware from the link below. Also see notes from NETGEAR product management.
download the v1.0.0.68 firmware by below link:
https://dl.dropboxusercontent.com/u/33388314/R7500-V1.0.0.68.zip
You can unzip the downloaded file to get the img file, then upgrade your R7500 with img file. Normally it should be work well after the firmware upgrade. But if you see anything abnormally, just like before, I suggest to reset router to factory default then use it again. and also please do the firmware upgrade by wired connection.
Below is the release note that we have done some changes on V1.0.0.68 firmware which compare to current official v1.0.0.52 firmware.
l Improve USB performance when user copy file from PC to USB disk, especially when you do the “drag and drop” method on Windows explorer for NTFS write.
l Improve 5GHz wireless performance in long range distance, especially in some noisy environment.
l If user set 2.4Ghz wireless channel in "Auto" option, we improve the 2.4G channel selection after system boot up.
l Add country codes support for China, Australia, and Canada region.
Bob Silver
NETGEAR Networking Assistant
Bob Silver
