Netgear R7500v2, R7800 + R8500 have shown up
Which of the three models do you want to know more about the most?
  • Total voters
    3
  • Poll closed .
To be honest, I think 160Mhz will kill the 5Ghz band especially in congested neighborhoods and apartments....
Said the same thing about 80 MHz. 5 GHz ain't dead yet. More limited range helps.
And remember, 160 MHz requires client-end support, too.
Thiggins do you think Intel/Apple will support it (future products)? I remember both refused to allow 40Mhz on the 2.4 Ghz Band earlier on their products for the same reason.
Don't know.
this is weird, because i could have sworn this thing was going to be broadcom as per the earlier posts in this thread
netgear still doesnt have a AC3100 class radio
but to be honest nitroqam is probably stupid on 2.4GHz and 5GHz
but looking back no evidence this was ever goin to come with broadcom solution
FCC docs NOV 4 show AC2600 X4S
im confused where this picture above posted with the same body as the R8500 came from
is it just R8500 picture or is there significant difference or way to tell?
Why not a LED for MU-MIMO so you can see when its in use, just a thought
It was probably supposed to be based on the Broadcom chipset originally but they may have later decided to go the Qualcomm route.
No.
That is like having an indicator for the FI working in a car.
I dont think its a bad idea
Nighthawk X4S (R7800) supports both 160 MHz contiguous and 80+80 MHz modes. With that, depending on the environment and channel congestion, when working with clients that support this feature, the R7800 can direct traffic in different 5 GHz sub bands, or combine 80+80 MHz in contiguous bands. With DFS certification in the future, more channels will become easily available.
Hmm I found one.
Sent from my Nexus 6 using Tapatalk
This could be a real game changer, either for good or bad, but if that's the case, why isn't it advertised as an AC4300 router (800 + 3466)? Shouldn't double channel width mean double transmission speed, at least in theory?
160MHz (80+80) works for 2-stream clients only. It doesn’t work for 4x4.
Please see the 160MHz video on Youtube
They cap the 160MHz mode for 1 and 2 stream devices only (not sure why though).
Because most devices are 1x1 and 2x2. 160 MHz mode, like MU-MIMO, is intended to most benefit those devices.
