Netgear ReadyNAS Duo Reviewed
Drive size
Does anyone know if there is a drive size limit on this NAS? I was thinking of using 1.5TB drives.
Thanks Lance
which doesnt mean they arent supported. in fact they run, if you can live with seagates crappy firmwares that is. so far the only known limitation on netgears nases are 48TB per volume.
netgear puts only drives on their HCL that dont have any firmware-issues. and even then the process is rather slow. by the time the drives get on the list they are probably already outdated :)
I think a more accurate statement would be "which doesn't mean they don't work".
If you use a drive that isn't on the list. Don't complain to NETGEAR if you run into problems.
you are right. there is a difference between working, not working and beeing on the HCL (guaranteed to work). :)
Lost Data
Hello,
I have a Netgear ReadyNAS Duo. The night i left the office there was a power failure. Thinking that the power would be back in a short while. i left the office because i have my UPS running.
This morning when i came, the netgear's power is off so i turned it on. Btw, this readynas is connected to my switch and is being shared to the network. To my surprise, i can't access the netgear in the network. so i check with readynas frontfview and the ip was was changed to dhcp so i changed it to it's previous IP. there were two hard disk but one was with status ok, the other is at resync. i can't find they shares that i created before and the files was gone. I wonder what happened.
will there be possibility that i can restore my files.
Please help.
