ashG
If this is the wrong forum, please move this to the correct one.
I'm having issues with my home network and external connection. With no real rhyme or reason, the entire setup will go belly-up This can happen twice a day, or it can go days without being an issue.
My setup is as follows
Charter Cable --> Motorola SB6141 --> ASUS RT-N66U w/ latest Merlin Firmware
Wired connection to router: Desktop computer, Synology 213 NAS, OOMA VoIP
Wireless connection: 2 phones, printer, 2 laptops, 3 tablets, Blu-Ray player, Wii
The modem's Connected to Internet and Connected to LAN lights have not ever changed to a disconnected state during these outtages, which leads me t believe the cable modem is not the culprit.
During these outtages, there is no pattern as to whether I can log in to the router or not. Sometimes I can log in and it will show "Disconnected from Internet", other times the login will simply time out and I'm left staring at a blank screen.
This situation began all of a sudden two weeks ago. It has happened on the four latest editions of the Merlin firmware and on the latest edition of the official firmware. The router's settings were cleared following each firmware change in order to rule out holdover settings issues. At this point, I am confident it is not related to a specific firmware revision.
I have replaced the cable from the modem to the router with a new cable just in case a bad run could be the issue.
What do I need to look for to identify the culprit? What variables should I ignore?
Thanks for your help in getting this sorted out!
