Hey All,
So i've done a search here but haven't found a solution.
I have an asus RT-AC68U and had Merlin's 380.68.4 firmware on it. I updated to 384.13 and since then all my Client list/network map has stopped working. I can still find the names of connected devices in the system log and DHCP leases.
I then did a factory reset in the hopes that if I started over from scratch and reconfigured my settings that it would solve the issue. Unfortunately, it has not solved the problem.
I've also rebooted and unplugged/re-plugged the router. Note: I know that the mapping can take some time but after 24 hours, it still hasn't shown up, not 1 client.
I've tried to go back to the 380 firmware but it won't let me... (i think this is by design though).
Thoughts on how I can solve this or go back to the other firmware? I use network map/client list for parental/time controls.
Thanks!
*Edit:
I do see a list of "offline" clients (when I click see offline clients) though when I attempt to set parental controls. They are not offline but the Router seems to think they are.. maybe that info will help.
Edit2: And I do use a /24 network.
***** EDIT: Got it to work.. was able to go back to original firmware (found older firmware, SCP, Putty)...got everything back to normal... so sorry to have bothered you both and welp..now I know I have a TM router
Thanks!
*Edit:
