Network map and multiple IP ranges
atx32
RMerlin, I am using 376.45 (RT-N66U) and have different IP ranges in dnsmasq for the main network versus the guest network. In my case the router and main LAN use 192.168.2.x and the guest network is 192.168.3.x. This works fine except the network map only shows clients that are assigned 192.168.2.x addresses. (I can see the guests in the System Log - DHCP leases screen though.)
Is it possible to have the network map show clients from all configured IP ranges or is that something that would touch too many places in the code? In any case it would be a nice enhancement if you decided to do it.
Thanks.
Networkmap was designed to only handle a single /24 network.
