drinkingbird
Part of the Furniture
I know the best thing for me to do here is to try to move the NVR PC over to area 1.
I just don't want to spend money at this time buying the equipment I need to achieve what I want.
Let's say I do that and move the NVR to area 1 and I am able to achieve what I need... one questions that's been lingering...
the Blue Iris NVR has an app which I use to view all cameras.. does this mean that the NVR web server will be on 192.168.2.x network and will I also need to have my smartphone connected to the same network in order to view the cameras?.. or is there a way for me to view them while connected to the main network 192.168.1.x?
Moving the NVR doesn't help unless you can also move router 2 to that area and have the wireless cameras connect to that, sounds like there may not be enough signal strength though?
Your issue is you need both networks in both locations right now. So unless you can get it all in once place, you will need VLANs for segmentation.
If you don't want to buy switches, then you can use one of the other options involving Fresh Tomato.
Spare router with FT running as pseudo smart switch + 68U R2 running FT acting as both a router and a smart switch
Two spare routers acting as pseudo smart switches keeping the 68U with Merlin firmware
You can't mix and match here. You can either have segmentation or not have it.
No segmentation means your phone and anything else can see the cameras (and vice-versa). Segmentation means you'll need to do a few extra steps to enable that connectivity, but it is possible.
With the "pseudo segmentation" of using one physical network but two different subnets means your phone won't be able to see the cameras unless you give it a static IP in the 192.168.2.x subnet. Honestly I don't really see that as a valid option, it is not really buying you much security or segmentation. Better than nothing, but you have much better options available.
