You appear to be experiencing a completely different issue that is unrelated to the issue discussed in this posted topic dealing with Network Service Filter values not being saved. In this topic the Network Service Filter page would refresh without a value being saved when the apply button was selected.Also, when using the Network Service Filter tab, this too no longer works. The screen is left with the spinner perpetually. Tried in multiple browsers. The apply button does seem to be broken
interesting on this tab, rather than a no-op, this tab will show the wait spinner then log you out after about 20 seconds or so
You should, if you haven't already, start a new separate topic with your issue since it is unrelated to this one. The Asus-Merlin subforum would likely be an appropriate place for your issue since you are running the Asus-Merlin firmware:
Asuswrt-Merlin
Use this forum for posts about all versions of this alternative firmware for ASUS wireless routers
