ColinTaylor
Part of the Furniture
That appears to be where the DROP messages are coming from.yes, I did, disabled it for an hour and enabled it again
yes, but why I got DROP packet when I correctly forward Cloudflare, is there any way to whitelist those IPs without turning off the DDOS completely. the problem happens from time to time.That appears to be where the DROP messages are coming from.
Just because you're forwarding ports doesn't mean you don't need DOS protection. Quite the opposite in fact. That's a huge range of addresses that you're allowing.yes, but why I got DROP packet when I correctly forward Cloudflare,
It's messy. You'd have to create ais there any way to whitelist those IPs without turning off the DDOS completely. the problem happens from time to time.
firewall-start
script like this:#!/bin/sh
iptables -I SECURITY -p tcp -s 103.21.244.0/22 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 103.22.200.0/22 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 103.31.4.0/22 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 104.16.0.0/13 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 104.24.0.0/14 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 108.162.192.0/18 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 131.0.72.0/22 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 141.101.64.0/18 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 162.158.0.0/15 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 172.64.0.0/13 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 173.245.48.0/20 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 188.114.96.0/20 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 190.93.240.0/20 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 197.234.240.0/22 -d 10.0.0.4 -j RETURN
iptables -I SECURITY -p tcp -s 198.41.128.0/17 -d 10.0.0.4 -j RETURN
I am not familiar with adding firewall-start script, just add those to the shell.Just because you're forwarding ports doesn't mean you don't want DOS protection. Quite the opposite in fact. That's a huge range of addresses that you're allowing.
It's messy. You'd have to create afirewall-start
script like this:
Code:#!/bin/sh iptables -I SECURITY -p tcp -s 103.21.244.0/22 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 103.22.200.0/22 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 103.31.4.0/22 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 104.16.0.0/13 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 104.24.0.0/14 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 108.162.192.0/18 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 131.0.72.0/22 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 141.101.64.0/18 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 162.158.0.0/15 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 172.64.0.0/13 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 173.245.48.0/20 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 188.114.96.0/20 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 190.93.240.0/20 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 197.234.240.0/22 -d 10.0.0.4 -j RETURN iptables -I SECURITY -p tcp -s 198.41.128.0/17 -d 10.0.0.4 -j RETURN
Start here: https://github.com/RMerl/asuswrt-merlin.ng/wiki/User-scriptsI am not familiar with adding firewall-start script, just add those to the shell.
I appreciate if there is any steps to follow, in order if i want to delete or modify a rule later
Thank you so much, i will look into and hope it will work
It would probably be a lot easier if you ran your web server on a non-standard port rather than the normal HTTPS port, 443. Using port 443 is a giant magnet for every hacker and port scanner on the planet (or Cloudflare). If you were to run it on a port like 28652 it's likely you wouldn't have a problem with DoS protection kicking in.Thank you so much, i will look into and hope it will work![]()
iptables
output you appear to have enabled Web Access from WAN on the router. This is a huge security concern so I suggest you disable that unless you really need it. If you need remote access to your router or LAN you could use the VPN server (which you already have running).Thanks Colin, for your suggestion, Actually I using the port forwarding to forward the 443 to Kemp loadbalancer and reverse proxy, which then be handle the request to my webserver using different port than 443,It would probably be a lot easier if you ran your web server on a non-standard port rather than the normal HTTPS port, 443. Using port 443 is a giant magnet for every hacker and port scanner on the planet (or Cloudflare). If you were to run it on a port like 28652 it's likely you wouldn't have a problem with DoS protection kicking in.
P.S. Looking at youriptables
Thanks for the update. I don't really understand your setup because I'm not familiar with the Kemp loadbalancer. But my concern was if your router was forwarding port 443 from the public internet rather than what was happening on the LAN. Ports 22, 23, 80 and 443 are probably the most common ports for scanner/hacker traffic.Thanks Colin, for your suggestion, Actually I using the port forwarding to forward the 443 to Kemp loadbalancer and reverse proxy, which then be handle the request to my webserver using different port than 443,
The file is calledquick question,
should I save the file like this firewall-start.sh using Vscode with UNIX line endings
firewall-start
. It doesn't have a filename extension.iptables-save -t filter -c
sorry for lateSSH into the router after you've tried to connect to 10.0.0.4 and enter this command to see if you're hitting the firewall rules as expected.
Code:iptables-save -t filter -c
dos2unix /jffs/scripts/firewall-start
service restart_firewall
yes, correct you are right, the JFFS custom scripts and configs was not enabled, my badYour firewall-start script has not run successfully. None of the rules have been added to the SECURITY chain. Check that you have enabled "JFFS custom scripts and configs" in the GUI under Administration - System.
It would also be a good idea to make sure the script is in Unix format rather than Windows format. Issue the following commands from an SSH session:
Code:dos2unix /jffs/scripts/firewall-start service restart_firewall
Welcome To SNBForums
