AgentSmith
*If this is the wrong forum please move to appropriate one.
I've had a small network for many years that I fumbled through the set up and some how made it work myself. It consists of older hardware & software that was used for mostly business productivity purposes and has served my needs to this point. BUT... I'm cutting the cord now and will be streaming to two android TV boxes and running two wifi tablets on to the network. At this point I've updated to a new faster/stronger router and through this process I'm realizing that I most likely need to re-configure the whole network to make it as secure as possible now that I'll have much more traffic on it and components that have a much higher probability of being hacked/hijacked/spywear/probed/malwear/etc
Here's what I'm working with Wan Side:
-Cable ISP -100/15mbs,
-ISP provided modem -300mbs
-ASUS RT-AC68U (AC1750) currently running FW version 382.1881 (looking at going to 384.10007)
-Linksys 10/100 switch (has Cisco algorithms or something)
LAN Side:
-Windows Server (performing DHCP)
-Two Windows XP pro workstations
-2 Wifi Tablets (android 4.4 & 5.5)
-2 Wifi Android TV boxes (7.1)
I believe I need the most help with LAN side IP adressing structure for the modem, router, server, workstatons, & tablets and especially WAN side port closing on the router in order to secure the network better.
1) Is there some website, advice, or posts that you can point me to to learn about what they are, how they work with each other and how to best structure my DHCP,Gateway,Subnetmask,DNS, across my network for security and speed?
2) How to check and close down any open ports on my router, I'm not seeing anything in the GUI?
Stuck In The Matrix
LAN Side:
Stuck In The Matrix
