We're technically talking three floors since there's a computer down in the basement and the router will be on the second floor of the house.
I've been following this site for a long time and am very grateful for all the work you guys do.
I'm realistic with my expectations. I know nothing beats being hardwired, but this will be logistically infeasible in my house so I need to go wireless.
Keeping in thiggin's article from not too long ago in mind where he no longer is outright recommending dual band (if I read it right) here goes:
My almost 5 year old Netgear WGR614 (original model) is showing me some age issues that suggest that it's not going to be long for this world. It's corresponding USB Adapter is on the second computer two floors away, down in the basement.
The performance has always been mediocre at best.
I'm ready and prepared to go wireless N all the way, no mixed. Choosing the router seems to be the easy part. I can go with D-Link and get either a 655 or DGL 4500. (The 855 is too expensive.) I can go Linksys and get a 600 or 610. I'm not loyal to one brand.
The computer that's two floors down from the router will need an adapter. It's my understanding that USB adapters typically are more flaky and more of a "bottleneck." Is that true?
If I go with any PCI adapter, none of them are dual band yet. This isn't the end of the world to me, either. If I'm going all N, am I best going to 5GHz or should I just stick with 2.4GHz?
Potential adapters I'm considering if the corresponding adapters from whatever company's router I buy aren't sufficient would be things like these:
http://www.hawkingtech.com/products/productlist.php?CatID=32&FamID=60&ProdID=379
or
http://www.hawkingtech.com/products/productlist.php?CatID=32&FamID=60&ProdID=377
^^ I'm surprised they don't have an N router out yet.
Anyways, those are just some of my ideas. I'm pretty wide open on the whole subject and I want to see what you all think is the best way for me to get this done right.
Thanks!
or
Thanks!
