mlai
Seems they tried to fix a lot of things in this version!
ASUS RT-AC68U Firmware version 3.0.0.4.374.339
Added:
1. Added Apple time machine feature in USB application.
2. Both NTFS and HFS+ format HDD are supported.
3. Added OpenVPN server.
4. Added OpenVPN/ PPTP/L2TP client.
5. Some devices like set top box, smart TV or Blu-ray player are not able to establish VPN connection. VPN client in router can help these devices to connect to VPN server.
6. Supported HFS+ format HDD
7. Added 2.4GHz beamforming option in advanced settings —> wireless —>professional
8. Added roaming assistant: allow to set the minimum RSSI to disconnect clients and let clients reconnect to Ap with better signal.
9. Added import CA file and manual edit option in OpenVPN client
10. Added option for tls-auth in OpenVPN server
11. Added private WAN IP checking in VPN server page.
Modified:
1. Enhanced FAT32 read/write speed
2. Modified roaming assistance algorithm for better roaming experience.
Fixed:
1. Fixed OpenVPN server *.ovpn file exporting issue while changed the protocol to TCP.
2. Fixed PPTP VPN client related issues.
3. Applied memory leak patch in media server.
4. Improved the 2.4GHz wireless throughput.
5. Improved the samba throughput while IPv6 enabled.
6. Adjusted 2.4GHz power saving algorithm to fix slow wireless in some special scenarios.
7. Fixed ASMedia 1053E USB 3.0 controller compatibility issue.
8. Fixed IPv6 related issues
9. Fixed quick internet setup UI issues when setup the router by wireless client.
10. Fixed WPS push button related issues.
11. Fixed the security related issues for httpd.
12. LAN user can now connect to OpenVPN server with DDNS name.
13. Fixed IPv6 default route missing issue.
14. Fixed BitTorrent related issues.
Added:
Modified:
Fixed:
