I just checked ASUS website and I noticed that 454 fw was gone.
does it mean we will see another new fw soon?
See just a few posts back in this very thread.
I just grabbed the pulled 454 update, and I'm definitely noticing an improvement in 2.4ghz throughput.
Haha the only thing that annoys me with Asus... why release a router with so many busted features / bugs initially in the first place!? Let it cook in the oven a bit more!
Its all about the competition - Netgear has their AC1900 released at the same time.
I have not experienced any slow downs on the 2.4 (haven't used 5ghz much on 454.) and I am at almost a week. I do have a 66u setup as a repeater so not sure if that changes something. Prior versions I would have to reset every couple days.
Spoke too soon last night had to reset since the 2.4 band was crawling.
new firmware is out
FW_RT_AC68U_3.004.374.501
2. Dual WAN in Fail Over mode does not fail back when primary line is up. If after router reboot backup line appeares to become active there is no way to work with primary line.
watchdog....have you played with those settings?)
This is a long-standing issue. Asus has been notified about it, but so far they don't seem to have addressed the issue (unless the new watchdog they recently added is the solution to this - have you played with those settings?)
Yes I did. .
Initially when I enabled watchdog, primary wan (dsl) and secondary wan (usb modem) was behaving hugely erratic with each connecting disconnecting each almost 10 seconds. .
But after that I increased initial ping wait delay from default 0 to 90..
After that I tried few experiments of manually disconnecting and connecting these primary and secondary (by their power off and on) and it was switching back on properly. . It takes little time but it did work ..
Now there are some disconnections after some "longer" periods of 5 to 30 minutes gap, it switches to the other and gets back after some time. . Not sure it is because of what or if it is due to watchdog..
Sent from my GT-N7100 using Tapatalk
I've tried to get this new firmware via the "Firmware version check" but it keeps saying that I have the most current version - even though I'm still on 374_205.
Any other way to update the firmware?
You have to download the file manually and upload it. There are 501 & 542 versions out.
Thanks!
Where could I download them?
Welcome To SNBForums
