I have update the router and have no problem in the GUI. I hope it is stable FW.I updated to 3.0.0.4.384_9165 on my GT-AX11000 and the GUI would not work. Tried a cold reboot, power cycle, etc. Would not come up (I eventually got to where it wanted a captcha), but it would not bring up the gui. Had to perform a factory reset. ASUS router FW sucks and their QA is garbage. I don't both with cases any longer given their support team's complete ineptitude. We'll see how stable it is, not holding out hope given the upgrade was not smooth.
"※Notice: It is recommended to restore to factory default settings by pressing the reset button on the bottom of the wireless router for 5 seconds after doing a firmware update."
https://www.asus.com/support/FAQ/1008000/
Especially relevant advice for new firmware that is still being improved.
OE
@Gooch4130, keep using the configuration as-is while it works.
However, if you have further issues, don't import your saved config file next time. As you effectively undid the goodness the reset to factory defaults offered.
'Okay' to restore saved backup config files, is not the same as 'optimal'.
Like I said, use it while it works. And keep this in mind if issues creep up.
Yep - I did that, it is working now. Fortunately I was able to restore settings. It's a bit tedious to reconfigure from scratch if you have 4 mesh nodes, 10 or so DHCP address, DDNS set up, and have labeled all devices. There are a number of other minor settings I change, but in general, I likely have far less to configure from scratch that most folks. Fortunately, I saved the config settings just prior to updating.
I appreciate the discourse . Something RMerlin does not take into account in his thread is the multitude of 'system-level' settings that are not exposed to end users. Restoring a config should not alter any 'non-configurable' settings. It should simply restore user settings. If that post is entirely accurate, it begs the question as to the purpose of the ability to save the config to begin with. I imagine it's not often users reset routers to defaults without having performed an upgrade first, which according to that post, would render the saved CFG file useless.
I don't necessarily consider them insults, just unfortunate facts. FW should not be this poorly QA'd and I don't know if you've worked a case with their support team, but I'd be more than happy to share with you emails from prior cases - it's some of the worst in the industry (this is an opinion shared by many). A flagship product should not release unstable FW that requires a complete reconfig after each update. I am not sure what your standards are, but I hold companies to a higher standard than what I have seen from Asus on this product.So next time and to save time, add the factory default reset and omit the insults.
OE
Fairly simple... if I buy it, I make it work as it is or I move on to something else.
(This started happening after last 2 firmwares for both AX routers)
Welcome To SNBForums
