al2813
I am looking to redo completely my home (and home office) network currently composed of ISP provided router plus some extra stuff. My current setup is:
- cable modem/router acting also as ground floor WIFI AP
- Main office GB switch (d-link)
- Small living room GB switch
- 1st floor Linksys router connected to the cable modem/router. It is in AP mode doing WIFI 1st floor AP + hub for multimedia/console upstairs.
I would like to go into a more SOHO type of setup and my idea is pretty much replacing everything. Need recommendations as to general setup as well as specific HW/SW:
- I will put My ISP modem/router in bridge mode and put behind it a dedicated router to control all traffic at home. I would also like to step up security so FW/UTM capabilities are a plus. As my technical knowledge is limited I would like to have something that is easy to configure and maintain (no CLI please . I've seen a lot of recommendations for running a Sophos UTM on a dedicated fanless NUC type of box.
- WIFI will be separated and I will get 2 APs for this purpose. I am pretty much decided to go for Unifi AC PRO for those.
- Do I need to replace my switch (currently a basic D-link)? Is there value in having a managed switch? I will need POE though to feed the Unifi APs.
- Can I keep my living room small switch hanging off the office main switch? I assume yes.
- Replace upstairs Linksys with a small switch similar to the one in the living room.
Many thanks for your advice/recommendations.
