petes67bird
Hi Everyone,
I just purchased an Asus RT N66U to replace my RT N56U. I have never really set up a proper wifi network and was hoping someone is kind enough to give me some basics to improve my coverage, range and strength. To start off with my internet is 65/20Mbps. I am looking to hook up a laptop, kindle fires, android phones and Panasonic TV wirelessly. Everything else I own will be wired with ethernet.
What I did with the RT N56U is basically just set up the wireless security in WPA2-PSK, plugged in a secure password and ran with it. My question is I never know what to put the 2.4 and 5 wireless at. They give you 20mhz, 20/40mhz or 40mhz options. I left the old router at 20/40 on both bands. Also should I tinker with the TX power or not. Any other advice you can give me setting up the wireless aspect of this router would be great. I read some place on here where you have to connect to 5 or 2.4 manually from your client but I have no idea how this is done. All I know is I turn my device on and find the signal and connect to it. When using wifi analyzer app, it shows that Channel 1, Channel 11-14 are all great channels. There arent many wifi signals near my home, I am out in the sticks a bit.
2 last questions, is it a bad idea to give your wireless network a name that can be linked directly to your home such as "tomswireless" etc. I never really thought of a security issue but just want to get some input on this. Last question, my ps3 is hooked up via a 100ft 5e cable. Would I see benefit doing something differently, maybe using cat 6 cable or should I be fine the way it is. Unfortunately the game room is on the opposite side of the home from the router.
Thanks so much to all the forum members here. I spend alot of time reading your posts and I cannot thank you guys enough. Pete
