New unofficial beta release for AC87u using new 5Ghz SDK QTN...
Might come off as a jerk now but have you rebooted the router after turning all that stuff off?
Yes I have :(
Will just have to wait for the next firmware update, do a factory reset, and then check again...
Yup, my settings are like that. Traffic Monitoring is off.
But it just says :
HW acceleration: Enabled (CTF only)
Hi There. I'm also having this issue after installing beta 6687. Looking at the log file it seems spanning tree protocol is enabled and is preventing FA from enabling. I cannot find any way of disabling STP from the UI.
In the logs I see "CTF: STP enabled, disable FA"
It's on the LAN -> Switch Control page (STP = Spanning Tree Protocol).
I wouldn't obsess too much over FA BTW, unless you have a gigabit-speed WAN link.
nvram set lan_stp=0
nvram commit
reboot
...ok...and after disabling stp the FA will be enabled by default in 6687? Or there is a code to enable it?!... asking that because I'm on gigabit plan...
Sent from my SM-G900F using Tapatalk
