nexenta
roamer
Hello,
has anybody tested Nexenta?
I found some older pots about Nexenta here in the board, but
it seems that nobody has collected real experience or at least didn't share them :confused:
Nexenta combines the OpenSolaris kernel with the Ubuntu userland.
The OpenSolaris distribution with the most number of packages (>13000)
It's a powerful, versatile server system based on ZFS.
http://www.nexenta.org/os
Roamer,
I tried both, NexentaStor and NexentaCore and liked them.
NexentaStor is good to manage for a non L*x system and free up to 1 TB storage. It has a good webinterface and cli.
The free size limit was the reason why I didnt use it further because its too expensive for my usage. If it fits below 1TB for you and you have enough CPU/Memory power then Its something to recommend.
NexentaCore is OpenSolaris with the APT (Debian) package system. I've run it for some time and will keep it on a testsystem for further testing cause its smaller than a standard OSOL.
Then there is Andre's EON which is also something to keep a eye on it.
