DIY NAS - A work log
Grunka,
Thanks and please let me know if you have any questions.
You should just be able to boot from the iso burned to a CD.
login root/eonsolaris
run format -e. It wil print if it see any drives. Paste me output if you can. ctrl-c to break out.
also run psrinfo -v and paste me that output if possible
The data on your drives will not be harmed or touched. The realtek driver has been fixed in opensolaris. EON is based off a later version than osol 2008.11, snv 104. The 64 bit release will have the realtek driver included but can be manually added.
I like alot about your board choice. I wish they hadn't used so dimm though.
