Another option if one already has Ethernet wired run into the other room, or doesn't mind running it to the other room, is using
AP mode. Or one can just use AiMesh mode when using all Asus AiMesh supported routers.
[Wireless Router] Introduction of Operation Mode
Media Bridge: Router can be configured in Media Bridge mode. The Media Bridge mode provides the fastest 802.11ac Wi-Fi connection for multiple media devices simultaneously.To set up the Media Bridge mode, you need
two Routers: One configured as the Media station and the other as a router. Configure one router as the first router and the second router as
an 802.11ac Media Bridge to provide a simultaneous 802.11ac Wi-Fi connection for your media devices such as computer, Smart TV, game console, DVR, or media player via Ethernet cable. Change to Media Bridge mode to provide a simultaneous 802.11ac Wi-Fi connection for your media devices. In Media Bridge mode, only wireless devices connect to the
Parent AP. Client devices need to be connected to the Media Bridge with a network cable.
Click here for detailed steps.
Access Point mode: In Access Point
(AP) mode, router connects to a wireless router through an Ethernet cable to extend the coverage of wireless signal to other network clients. In this mode, the firewall, IP sharing, and NAT functions are
disabled by default.
AiMesh Node: You can set this router as an AiMesh node to extend an existing AiMesh routers WiFi coverage.
1. Factory resetting this router will allow it to join an existing AiMesh network.
2. Please go to the AiMesh settings page of your existing router to add an AiMesh node.
