jackiechun
Just providing a datapoint, 384.13 on AC86U + latest NextDNS installer (nextdns version 1.4.27)
= running perfectly.
Just providing a datapoint, 384.13 on AC86U + latest NextDNS installer = running perfectly.
Make your datapoint complete: provide the NextDNS version you're running.
In two minutes, 'the latest installer' will be meaningless.![]()
i used the instructions on the github site. when i query the version, it comes up as 1.4.25...
Re-run the installer to upgrade to 1.4.27.I have the same issue. Can't keep nextdns installed, keeps breaking entware install. {AC86U - 384.15_beta1}
sh -c 'sh -c "$(curl -sL https://nextdns.io/install)"'
Paid services don't belong in amtm, imho. It may be free for now, but it will become a chargeable service. While myself and other script writers are open to donations, we do not ask for them before we provide users with our scripts.I can confirm that the issue is resolved in 1.4.27. I had to run the installer again and check for updates . installed and rebooted and entware is still installed.
@Olivier Poitrey we should get this installer integrated with amtm so that we can run updates in an integrated fashion...
Ah Thanks for pointing that outPaid services don't belong in amtm, imho. It may be free for now, but it will become a chargeable service. While myself and other script writers are open to donations, we do not ask for them before we provide users with our scripts.
No. If you want ad-blocking and CloudFlare, you should probably be using Diversion on the router.Is it possible to use Cloudflares fast 1.1.1.1 DNS and the malware/adblocking features of nextDNS on an AsusWRT router?
Edit:
I have pinged 1.1.1.1 ~ 16ms
ping 45.90.28.155 ~ 30ms
However, Merlin has integrated free/paid services like OpenVPN
People might be confused though since the first hit on "OpenVPN" in DuckDuckGo (and Google) leads to https://openvpn.net which offers commercial services.There is nothing paid for about OpenVPN. It's a 100% open source VPN client/server, it does not promote any commercial service.
Feb 6 23:36:09 ac86u nextdns[16103]: Starting NextDNS 1.4.28/linux on 127.0.0.1:5342
Feb 6 23:36:09 ac86u nextdns[16103]: Listening on TCP/127.0.0.1:5342
Feb 6 23:36:09 ac86u nextdns[16103]: Starting discovery resolver
Feb 6 23:36:09 ac86u nextdns[16103]: Listening on UDP/127.0.0.1:5342
Feb 6 23:36:11 ac86u nextdns.init: Stopped
I assumed they were closely related
Check your syslog for nextdns messages. It’s pretty chatty when it’s working. Post what you find.Just so I understand correctly ... If I install NextDNS I won't need to use Diversion? Or do I just leave it on/installed?
Edit: I have NextDNS installed but the Web UI for NextDNS doesn't indicate the router is connected. And I still have Diversion on.
Run the install again to upgrade to v1.4.31. They fixed a crash in that version.I don't see anything I understand to be NextDNS in the logs, but am I suppose to add DNS servers in the UI anywhere?
I'll take a look again, but just to clarify what should I be looking for in the logs? Anything with "NextDNS" labelled?
Fixed in 1.4.31.Upgraded to 1.4.28 and now DNS no longer works...
Welcome To SNBForums
