laracroftonline
Just started using nextdns and must say i’m impressed.
And you'll be more and more as time goes byJust started using nextdns and must say i’m impressed.
My addresses changed from *.*.*.0 for MONTHS which was linked to my ASUS Router. Last Monday they changed to *.*.*.114 and broke everything that morning. In fact, I've not put the new addresses into the ASUS Router yet as I've been waiting for an official answer.So it was a bug that was corrected on website, because my ipv4 linked ip servers definitely changed from 45.90.28.0 and 45.90.30.0 to 45.90.28.60 and 45.90.30.60
@Smokey613, so you bought NextDNS and now you stopped using it? I thought you loved it?
The “script” installs a DNS service (application) on the router to connect to NextDNS over DoH. It has conditional configuration which allows you to send different clients to different profiles. I think it’s the only way to handle multiple NextDNS profiles behind one router WAN IP.What does the script achieve that attempting to manually configure does not - is manual config even possible with more than one nextdns profile as I'm struggling?
Let it also be noted if you install nextdns on the router, it becomes your "only" dns solution unless you decide to uninstall it.Hi and thanks for the NextDNS service - I really like the service and would like to integrate it into my asus router but I have a few questions @
Olivier Poitrey or @anyone else who may be able to help.
My current setup - diversion, skynet and unbound to block as much as possible and be as private (elatively) as possible.
What I think I want to achieve is as follows - I have three nextdns profiles - one for normal devices. one for kids and one for smart tv's.
I was previously using dnsfilter with custom dns providers to achieve some differentiation between these and using different dns for each.
Having attempted the same putting in standard ip4 address of each profile for nextdns none of these devices seem to be connecting apart from my pc which I have linked the service to on the setup page.
How come there are no screenshots of what this script achieves - github and here point to each other for more info and I'm struggling to understand what the script does?
Would also like to see the answers to gattaca above.
I'll definitely be interested to see rmerlin's integretation into AMTM hopefully.
Thanks![]()
Via the router's DNSFilter function?Does anyone know how to make one of my devices bypassing completely nextdns app on router?
You sir are a genius and I've never remembered thatVia the router's DNSFilter function?
You can use MAC addresses and avoid the static assignments.I guess I now need to engage brain and use the following: https://github.com/nextdns/nextdns/wiki/Conditional-Configuration to setup individual clients to devices - I will have to bind all their IP's I believe to make them static?
Welcome To SNBForums
