Nginx: Unable to open primary script
zidler
I spent last 48 hours without sleep trying to fight it. No luck =( Please HELP!
I swear I'm gonna personally buy beer in any bar to whomever solve this.
Technically, this is a problem of PHP-fpm server.
What I got in my log is:
2017/02/13 01:25:20 [error] 4041#0: *1 FastCGI sent in stderr: "Unable to open primary script: /opt/share/www/xxx/web/index.php (No such file or directory)" while reading response header from upstream, client: 141.39.226.225, server: xxx, request: "GET /index.php HTTP/1.1", upstream: "fastcgi://127.0.0.1:9000", host: "xxx:81"
[me@AC5300][/opt/etc]> ls /opt/share/www/xxx/web/index.php
-rwxrwxrwx    1 nobody   nobody      1.6K Feb 12 22:21 /opt/share/www/xxx/web/index.php*
drwxrwxrwx    5 nobody   nobody      4.0K Feb 13 01:12 ./
drwxrwxrwx   10 nobody   nobody      4.0K Jan 27 03:52 ../
drwxrwxrwx    2 nobody   nobody      4.0K Aug  1  2015 css/
-rwxrwxrwx    1 nobody   nobody       902 Jan 27 02:57 favicon.ico*
-rwxrwxrwx    1 nobody   nobody       713 Jan 27 02:57 htacc*
drwxrwxrwx    3 nobody   nobody      4.0K Jan 27 02:57 images/
-rwxrwxrwx    1 nobody   nobody        10 Feb 12 21:54 index.html*
-rwxrwxrwx    1 nobody   nobody      1.6K Feb 12 22:21 index.php*
drwxrwxrwx    3 nobody   nobody      4.0K Jan 27 02:57 js/
-rwxrwxrwx    1 nobody   nobody        26 Jan 27 02:57 robots.txt*
-rwxrwxrwx    1 nobody   nobody        61 Jan 27 02:57 sfDoctrinePlugin*
-rwxrwxrwx    1 nobody   nobody        32 Jan 27 02:57 sfFormExtraPlugin*
[me@AC5300][/opt/etc]> cat /opt/etc/nginx/nginx.conf
user  nobody;
worker_processes 1;
# error_log logs/error.log;
#error_log logs/error.log notice;
#error_log logs/error.log info;
#pid logs/nginx.pid;
# access_log /opt/var/log/nginx/access.log;
# error_log /opt/var/log/nginx/error.log;
events {
   worker_connections 128;
   multi_accept        on;
http {
   include mime.types;
   default_type text/html;
   index  index.php index.html index.htm;
   server_tokens off;
   sendfile on;
   tcp_nopush on;
   tcp_nodelay on;
   keepalive_timeout 10;
   types_hash_max_size 2048;
   # File Cache Settings
   open_file_cache          max=5000  inactive=20s;
   open_file_cache_valid    30s;
   open_file_cache_min_uses 2;
   open_file_cache_errors   on;
   # Gzip Settings
   # gzip_proxied expired no-cache no-store private auth;
   gzip on;
   gzip_vary on;
   gzip_min_length 10240;
   gzip_comp_level 2;
   gzip_http_version 1.1;
   # gzip_static on;
   gzip_proxied any;
   gzip_types text/plain text/css text/javascript application/json application/x-javascript text/xml application/xml application/xml+rss;
   gzip_disable "MSIE [1-6]\.";
   gzip_buffers 16 8k;
   ssl_session_cache    shared:SSL:10m;
   ssl_session_timeout  10m;
   ssl_ciphers  HIGH:!aNULL:!MD5;
   ssl_prefer_server_ciphers on;
   fastcgi_cache_path /tmp/nginx levels=1:2 keys_zone=microcache:10m max_size=1000m inactive=60m;
   log_format main '$remote_addr - $remote_user [$time_local] "$request" '
   '$status $body_bytes_sent "$http_referer" '
   '"$http_user_agent" "$http_x_forwarded_for"';
   # access_log logs/access.log main;
   charset UTF-8;
   # fastcgi_connect_timeout 300;
   # fastcgi_send_timeout 300;
   # fastcgi_read_timeout 300;
   # fastcgi_buffer_size 32k;
   # fastcgi_buffers 4 32k;
   # fastcgi_busy_buffers_size 32k;
   # fastcgi_temp_file_write_size 32k;
   # client_body_timeout 10;
   # client_header_timeout 10;
   # send_timeout 60;
   # output_buffers 1 32k;
   # postpone_output 1460;
   fastcgi_buffer_size 128k;
   fastcgi_buffers 256 16k;
   fastcgi_busy_buffers_size 256k;
   fastcgi_temp_file_write_size 256k;
   # server {
       #     listen       81;
       #     server_name  localhost;
       #     #charset koi8-r;
       #     #access_log  /opt/var/log/nginx/host.access.log;
       #     location / {
           #         root   /opt/share/nginx/html;
           #         index  index.html index.htm;
           #     #error_page  404              /404.html;
           #     # redirect server error pages to the static page /50x.html
           #     error_page   500 502 503 504  /50x.html;
           #     location = /50x.html {
               #         root   html;
               server {
                   listen 81;
                   set $host_path '/opt/share/www/xxx/web';
                   root $host_path;
                   server_name xxx;
                   # access_log /var/log/nginx/site.ru-access.log;
                   # error_log /var/log/nginx/site.ru-error.log;
                   location ~ \.php$ {
                       include fastcgi_params;
                       fastcgi_intercept_errors on;
                       fastcgi_pass   127.0.0.1:9000;
                       # fastcgi_pass   unix:/var/run/php5-fpm.sock; # connect to a unix domain-socket:
                       fastcgi_index  index.php;
                       # fastcgi_param   SCRIPT_FILENAME    $document_root$fastcgi_script_name;
                       # fastcgi_param   SCRIPT_NAME        $fastcgi_script_name;
                   # location = /favicon.ico {
                       #     log_not_found off;
                       #     access_log off;
                       # location = /robots.txt {
                           #     allow all;
                           #     access_log off;
                           # location / {
                               #     # This is cool because no php is touched for static content.
                               #     # include the "?$args" part so non-default permalinks doesn't break when using query string
                               #     try_files $uri $uri/ /index.php?$args;
                               # location ~* \.(js|css|png|jpg|jpeg|gif|ico)$ {
                                   #     expires max;
                                       #     root   html;
[me@AC5300][/opt/etc]> cat /opt/etc/php5-fpm.d/www.conf
[www]
;prefix = /path/to/pools/$pool
user = nobody
group = nobody
listen = 127.0.0.1:9000
listen.owner = nobody
listen.group = nobody
listen.mode = 0777
; priority = -19
pm = dynamic
pm.max_children = 5
pm.start_servers = 2
pm.min_spare_servers = 1
pm.max_spare_servers = 3
;pm.process_idle_timeout = 10s;
;pm.max_requests = 500
;pm.status_path = /status
; The ping URI to call the monitoring page of FPM. If this value is not set, no
; URI will be recognized as a ping page. This could be used to test from outside
; that FPM is alive and responding, or to
; - create a graph of FPM availability (rrd or such);
; - remove a server from a group if it is not responding (load balancing);
; - trigger alerts for the operating team (24/7).
; Note: The value must start with a leading slash (/). The value can be
;       anything, but it may not be a good idea to use the .php extension or it
;       may conflict with a real PHP file.
; Default Value: not set
;ping.path = /ping
; This directive may be used to customize the response of a ping request. The
; response is formatted as text/plain with a 200 response code.
; Default Value: pong
;ping.response = pong
; The access log file
; Default: not set
;access.log = log/$pool.access.log
; The access log format.
; The following syntax is allowed
;  %%: the '%' character
;  %C: %CPU used by the request
;      it can accept the following format:
;      - %{user}C for user CPU only
;      - %{system}C for system CPU only
;      - %{total}C  for user + system CPU (default)
;  %d: time taken to serve the request
;      - %{seconds}d (default)
;      - %{miliseconds}d
;      - %{mili}d
;      - %{microseconds}d
;      - %{micro}d
;  %e: an environment variable (same as $_ENV or $_SERVER)
;      it must be associated with embraces to specify the name of the env
;      variable. Some exemples:
;      - server specifics like: %{REQUEST_METHOD}e or %{SERVER_PROTOCOL}e
;      - HTTP headers like: %{HTTP_HOST}e or %{HTTP_USER_AGENT}e
;  %f: script filename
;  %l: content-length of the request (for POST request only)
;  %m: request method
;  %M: peak of memory allocated by PHP
;      - %{bytes}M (default)
;      - %{kilobytes}M
;      - %{kilo}M
;      - %{megabytes}M
;      - %{mega}M
;  %n: pool name
;  %o: ouput header
;      it must be associated with embraces to specify the name of the header:
;      - %{Content-Type}o
;      - %{X-Powered-By}o
;      - %{Transfert-Encoding}o
;  %p: PID of the child that serviced the request
;  %P: PID of the parent of the child that serviced the request
;  %q: the query string
;  %Q: the '?' character if query string exists
;  %r: the request URI (without the query string, see %q and %Q)
;  %R: remote IP address
;  %s: status (response code)
;  %t: server time the request was received
;      it can accept a strftime(3) format:
;      %d/%b/%Y:%H:%M:%S %z (default)
;  %T: time the log has been written (the request has finished)
;  %u: remote user
; Default: "%R - %u %t \"%m %r\" %s"
;access.format = "%R - %u %t \"%m %r%Q%q\" %s %f %{mili}d %{kilo}M %C%%"
; The log file for slow requests
; Note: slowlog is mandatory if request_slowlog_timeout is set
;slowlog = log/$pool.log.slow
; The timeout for serving a single request after which a PHP backtrace will be
; dumped to the 'slowlog' file. A value of '0s' means 'off'.
; Available units: s(econds)(default), m(inutes), h(ours), or d(ays)
; Default Value: 0
;request_slowlog_timeout = 0
; The timeout for serving a single request after which the worker process will
; be killed. This option should be used when the 'max_execution_time' ini option
; does not stop script execution for some reason. A value of '0' means 'off'.
; Default Value: 0
;request_terminate_timeout = 0
; Set open file descriptor rlimit.
; Default Value: system defined value
;rlimit_files = 1024
; Set max core size rlimit.
; Possible Values: 'unlimited' or an integer greater or equal to 0
;rlimit_core = 0
; Chroot to this directory at the start. This value must be defined as an
; absolute path. When this value is not set, chroot is not used.
; Note: you can prefix with '$prefix' to chroot to the pool prefix or one
; of its subdirectories. If the pool prefix is not set, the global prefix
; will be used instead.
; Note: chrooting is a great security feature and should be used whenever
;       possible. However, all PHP paths will be relative to the chroot
;       (error_log, sessions.save_path, ...).
;chroot =
; Chdir to this directory at the start.
; Note: relative path can be used.
; Default Value: current directory or / when chroot
chdir = /
; Redirect worker stdout and stderr into main error log. If not set, stdout and
; stderr will be redirected to /dev/null according to FastCGI specs.
; Note: on highloaded environement, this can cause some delay in the page
; process time (several ms).
; Default Value: no
;catch_workers_output = yes
; Limits the extensions of the main script FPM will allow to parse. This can
; prevent configuration mistakes on the web server side. You should only limit
; FPM to .php extensions to prevent malicious users to use other extensions to
; exectute php code.
; Note: set an empty value to allow all extensions.
; Default Value: .php
;security.limit_extensions = .php .php3 .php4 .php5
; Pass environment variables like LD_LIBRARY_PATH. All $VARIABLEs are taken from
; the current environment.
; Default Value: clean env
;env[HOSTNAME] = $HOSTNAME
;env[PATH] = /usr/local/bin:/usr/bin:/bin
;env[TMP] = /tmp
;env[TMPDIR] = /tmp
;env[TEMP] = /tmp
; Additional php.ini defines, specific to this pool of workers. These settings
; overwrite the values previously defined in the php.ini. The directives are the
; same as the PHP SAPI:
;   php_value/php_flag             - you can set classic ini defines which can
;                                    be overwritten from PHP call 'ini_set'.
;   php_admin_value/php_admin_flag - these directives won't be overwritten by
;                                     PHP call 'ini_set'
; For php_*flag, valid values are on, off, 1, 0, true, false, yes or no.
; Defining 'extension' will load the corresponding shared extension from
; extension_dir. Defining 'disable_functions' or 'disable_classes' will not
; overwrite previously defined php.ini values, but will append the new value
; instead.
; Note: path INI options can be relative and will be expanded with the prefix
; (pool, global or /usr)
; Default Value: nothing is defined by default except the values in php.ini and
;                specified at startup with the -d argument
;php_admin_value[sendmail_path] = /usr/sbin/sendmail -t -i -f www@my.domain.com
;php_flag[display_errors] = off
;php_admin_value[error_log] = /var/log/fpm-php.www.log
;php_admin_flag[log_errors] = on
;php_admin_value[memory_limit] = 32M
I've done
[me@AC5300][/opt/etc]> chown nobody:nobody -R /opt/share/www/xxx/
[me@AC5300][/opt/etc]> chmod -R 777 /opt/share/www/xxx/
[me@AC5300][/opt/etc]> namei -om  /opt/share/www/xxx/
f: /opt/share/www/xxx/
 drwxr-xr-x me     root   /
 lrwxrwxrwx me     root   opt -> tmp/opt
   drwxrwxrwx me     root   tmp
   drwxr-xr-x me     root   opt
 drwxr-xr-x me     root   share
 drwxrwxrwx me     root   www
 drwxrwxrwx nobody nobody xxx
[me@AC5300][/opt/etc]> stat /opt/share/www/xxx/web/index.php
  File: '/opt/share/www/xxx/web/index.php'
  Size: 1604          Blocks: 8          IO Block: 4096   regular file
Device: 801h/2049d    Inode: 172629      Links: 1
Access: (0777/-rwxrwxrwx)  Uid: (65534/  nobody)   Gid: (65534/  nobody)
Access: 2017-02-12 22:21:29.000000000 +0000
Modify: 2017-02-12 22:21:36.000000000 +0000
Change: 2017-02-13 01:41:48.000000000 +0000
 Birth: -
Same output in the log file. =((((
M Unable to enable Ethernet Backhaul in XT12 ASUS Wi-Fi 3
