Skynet No data to display for only outbound?
Kobalt
I ran into a weird problem today, was debugging an issue at my cousin's place, they were trying to stream a game and today it wasn't working at all
so, I tried to go to the website in question to see if anything was there, and it couldn't connect, so I tried a vpn, and it connected
I then went to the Asus router's Skynet page to see if it was being blocked there for some reason, and the GUI just shows
I then ssh into the router, and did a firewall debug watch to see if anything was popping up there and sure enough, the IP in question was being blocked
No idea why 205.220.231.24 was being blocked but it was. I just whitelisted that IP and all is working again
My question is, why doesn't it show outbound connections being blocked on the GUI? Inbound works fine, and the system log is set to "notice" and "debug" as normal
ideas?
As for how that IP got there in the first place, I assume one of the block lists added that by mistake
I would suggest to re-start Skynet, in case something is hung etc [Skynet Menu Option 8].
Also 'Hard' refresh the browser ... Press Ctrl+F5 (If that doesn't work, try Shift+F5 or Ctrl+Shift+R).
Thanks, yeah, already restarted it, and refreshed the browser cache, nothing has changed so far. I ran out of time to debug the issue, but I play to try again next weekend
Re the empty logs
To me it's completely normal. Skynet blocks any malicious outgoing traffic and logs it. If there's nothing malicious going out then skynet has nothing to block and the log stays quiet. A good thing.
You would have a problem if you did see entries in those. If skynet is logging incoming blocks then it's, again, working fine.
Re the empty logs
but the thing is, it *was* blocking that IP, and that caused the problems, and since it was blocking it, it should have shown the block in the GUI
If skynet was blocking it it would have been in the logs. The fact that the other logs were okay shows skynet was active.
In testing the IP resolves fine. I added it to the blacklist and it failed to resolve. I whitelisted it and it resolved.
I think something strange is happening on your cousin's router - that or the IP was manually added to the blacklist at sometime, or they're using a custom blacklist. There could be some strange configuration error (LAN/DHCP/DNS). For sure the IP doesn't appear in the default blacklist. Do you know which blacklist is installed?
