No dropbear on system log
matthew_eli
Hi, is that normal I don't see any dropbear entrues in my system log when I succesfully enter via SSH? I've a RT-BE86U with 102.3 merlin FW installed and scribe
It’s not normal for Merlin firmware, but unknown what the expected outcome should be with Scribe, since it can filter and redirect log messages.
But I can't find any entries anywhere in the scribe logs
That's with Scribe running (version 3.2.1) and uiScribe (1.4.6) in System Messages. Which versions are you running? The release versions aren't compatible with your router.
I'm using latest develop versions for both Scribe and uiScribe
Ok, it seems reinstalling Scribe did the trick. BTW, why I'm seeing a different port in the log for dropbear than the one I'm selecting for accessing the router via SSH? Is that normal?
That's the source port (the client's endpoint), not the destination port (the router's).
