SoCalReviews
I guess not normal applies to all four of my 68p routers.Not normal.
Are you a collector?
I actually own and manage ten Asus routers. They are for personal and business use.It seems the TX Power Adjustment option was not fully removed then.
I have a number of older wireless routers I'd be willing to sell if you are interested.Seems like he is - oh, well...
(and new to an old discussion)
Round 2... FIGHT.
As long as a lap dog isn't tossed into the fight it's all good. No one likes a barking Chihuahua.Round 2... FIGHT.
If you really want to reduce wifi signal power?... Ethernet cable and I use it everywhere I can.Any how, 10db difference when you increase or decrease power level by 10. So from hi limit 100mW x10 is 1Watt. Higher Wattage is more heat, probably more noise and more QRM. I was always thinking, do more with less.
I got you beat on that one... I gave all my WRT's away years ago. I gave an E4200 v1 away last year to a friend. I sold one WNDR-3700 v2 but I have a few of those laying around. I'm keeping my N66U's as modern relics.... they still blast 2.4Ghz pretty well.erm no - I've got a couple of WRT's handy... the rest went to craigslist or eWaste...
It's a grin not a laugh. I was just adding a side comment about my preference of using Ethernet cable but yes... of course Tx power adjustment is something I use a lot. I like to use 2.4Ghz at reduced power.Huh! You, laughing at yourself? I thought you were talking about TX adjustment hi and/or lo.
Why is the power adjustment option is still there and working on my 68P running firmware 3831? I want to reduce the amount of power anyway... not increase it.
@@ -133,6 +192,7 @@ var ttc = '<% nvram_get("territory_code"); %>';
var is_KR_sku = in_territory_code("KR");
var is_CN = in_territory_code("CN");
var is_TW_sku = in_territory_code("TW");
+var is_US_sku = in_territory_code("US");
//wireless
var wl_nband_title = [];
@@ -236,6 +296,9 @@ var band5g_support = isSupport("5G");
var live_update_support = false; // isSupport("update");
var cooler_support = isSupport("fanctrl");
var power_support = isSupport("pwrctrl");
+if(is_US_sku)
+ power_support = false;
Btw... are you using a 88u or 3100 router with updated firmware? The Asus support rep told me those should still have Tx power adjustment with the new firmware. That would be another option to have Tx power adjustment if I decide to return the 1900P because of this issue. It's too bad because everything else about the 1900P is really good.[/QUOTE said:Yes, playing with NG R7800 and Asus RT-AC3100 side by side. I don't fiddle with power setting. I am comparing other things. Speaking of low power, I worked S. Africa with 500mW home brew TX dangling at a feed point of a gain antenna
facing long path using coherent CW mode. I know what I am doing, how to do it. You do your thing, I do my thing.
No idea. I'm just repeating what Asus told me a few weeks ago (that they were removing that TX setting for the US SKUs), and I do see that code having been added in 3831...
Ok, I see that has been added to the official firmware code. For whatever reason the 68P still has the Tx power option... for now. But for the future firmware this is where the magic takes place with third party firmware developers. Do we believe in magic? Do we believe in magicians? Yes we do...
Thread starter | Title | Forum | Replies | Date |
WAN Light blinks then sticks bright, dim WPS/USB, no power light (jealous cat peed on ac88u) [Fixed] | ASUS AC Routers & Adapters (Wi-Fi 5) | 0 |
Welcome To SNBForums
