Solved No webGUI
Diveblaster
Hi
Today when I logged into my router all AMTM webgui parts have disappeared. To my knowledge nothing has been updated. Im running on a RT-AXE16000 with FW: 3004.388.6_2_rog.
amtm is installed as you can see in picture.
Check that the router can see your USB drive!
My USB drive is alive and the icon is blue. Its lights are on and blinking.
Is there a way of testing it more if thats the problem?
From logfile:
NTP timeout (100s) reached, date is router default
Tue Apr 9 06:47:25 DST 2024 Probing 'ext4' on device /dev/sda1
Running disk check with command 'e2fsck -p' on /dev/sda1
asususb: recovering journal
asususb: clean, 1487/14655488 files, 4190849/58607120 blocks
Tue Apr 9 06:47:25 DST 2024 Disk check done on /dev/sda1
The only thing standing out is NTP timeout...no timepout before what i can see otherwise its the same.
Does the disk check log (dcl) show any errors, maybe after a reboot?
Which ntp servers does ntpMerlin use?
A reboot did the trick. First time this has happened :)
