Jack Yaz
Part of the Furniture
To be honest, you probably wouldn't have a soul come near you!Like standing stark naked for a week in the concourse of Grand Central Station.
They wouldn’t notice?To be honest, you probably wouldn't have a soul come near you!
So after doing your reset procedure, in what order would you reintroduce Skynet, Diversion, Pixelserv-TLS, and OpenVPN Server? (Hopefully Skynet first. I'm already nervous going for a week.)
That's great... but your earlier post suggested waiting a week between each change to check for stability... So I'm up to ~7-8 weeks between now and Skynet?
Also. "disk checker script?"
Also... separate issue that has been annoying me... anytime I reboot, seems like I have to go into the OpenVPN server and turn it off and back on, or else it doesn't work. That was the case with the 3100 and now with this 3200... Probably a separate thread for that one.
Thanks bro.
Thanks bro.
Are you talking about my 'earlier post' from 2015? I don't think you read that correctly.
You must be doing something different (wrong?) than the norm if the same issue is following you from a previous router?
I and many others have been using amtm, Diversion, Skynet and the other scripts that I at least consider it a 'known/good' state. You don't need to verify for too long up to that point. Anything you change past defaults though, you're in exploratory mode.![]()
After doing a full reset to factory defaults and then minimally and manually configuring the router to secure it and connect to the ISP, what I do with the available scripts is:
- Format jffs on next reboot and then proceed to reboot the router 3 times in the next 15 minutes or so, waiting 5 to 10 minutes in between the next reboot.
- Enable OpenVPN server and do a quick test with my cell phone from 4G (not WiFi) to see if I reach the network.
- Install the FreshJR QOS script (because it doesn't require Entware).
- Install the amtm script.
- Insert the USB drive I'll use and format it to Ext4 with journalling enabled.
- Create a swap file using amtm (not the same as a swap disk). Reboot the router.
- Install the disk checker script.
- Install Diversion and let it install Entware and pixelserv-tls.
- Install Skynet and/or any other script in any order you wish from here.
- Reboot the router and wait at least 5 minutes for the router to be fully empowered.
I wouldn't worry about being too nervous for a few more minutes, all of the above can be done in short order.
With each step above make sure you are testing the OpenVPN Server and taking good notes of the options you're enabling in each script.
But the order above is what I stick to when I'm doing this.
Yes, this is how I interpreted it. Wait a week between changes. I would love to only wait a week before bringing back all of my scripts.“.......and if things are stable at this point for an extended period (at least a week), other available router options may be introduced one at a time and added to as (and if) they prove stable.”
A second for this question. Or, if ext4, why "journaling on?" Doesn't that run through the drive life much faster?@L&LD,I was under the impression that Diversion installation recommended disk formatting to ext2. Have these recommendations changed recently or is this your preference? I have always used ext2 but been thinking lately about trying ext4 instead. Have you come across any performance issues with this format?
So @L&LD, what about setting up the minimal configuration, using the migrate version of the backup and restore script, and posting that to be used to set alll your recommended default provisons?
Why do I sometime need to do a factory default reset?
In addition to those user-entered settings, there's all those system level settings I previously mentioned. Sometimes, the manufacturer will need to change some of those low-level settings, either to resolve an issue, or to adapt to a newer wireless driver that they started using.
If you fail to do a factory default reset, then your router will still have the old values, and it will keep using them. That can lead to performance issues (especially in changes related to the wireless driver), or flat out odd behaviour (if one of the settings no longer works the same way as before).
Can I just restore my saved settings after I do a factory default reset?
No. The idea behind a factory default reset is to have your router start using the NEW default values. If you restore your saved settings, you will overwrite those new values with the old ones, and you are back to square one.
This is similar to having a PC with a corrupted Windows installation. If you reformat, and immediately after you restore a Ghost/TrueImage/Clonezilla backup on top of the reformatted Windows, you are back to where you were before you did all that work.
Factory default reset: before, or after flashing?
Since the goal is to use the NEW default values that are included in the NEW firmware, the factory default reset must be done while the NEW firmware is already flashed. Doing so before flashing will leave you running the OLD default values.
Step-by-step instructions from L&LD on preparing the USB drive for AMTM, supplementing his advice further back in this topic, can be found here:
https://www.snbforums.com/threads/diversion-the-router-ad-blocker.48538/page-123#post-479568
You’re most welcome; it’s the least I can do.Thanks martinr for keeping this thread updated with the latest 'best practices'. It's a constantly moving target, but so are we.![]()
It means exactly what it says. Nothing more, nothing less. Only enable options that you need. And disable the options you don't need.
This is what I consider a base line.
After new firmware loaded.
- Use new ssid's for all bands and radio's (most likely easier to do after the wizard completes for dual 5GHz band radio's capable routers). You can reuse the old passwords though.
I wonder the exact same thing.I just run into this good thread while doing some research before updating firmware on my RT-AC68U.
The above item in bold has called my attention.
Why is it suggested to use new SSIDs? Having to re-enter network credentials in one or two dozen devices can be a real pain. I have done it some times in the past, but not every time I upgraded firmware or even router... only when I thought there was a reason for it.
Am I missing something ?
If I had i.e. "SS24" as old SSID,
when i reset to default of course it changes to asus default,
but why can i not use "SS24" again?
Doent the router totally "forget" old SSIDs at a reset or why should it mess thing up?
Reconnecting all pheripheral devices to a new SSID is a lot of work if You have many devices (phones are easy, some other devices time consuming)
Great guide, a few settings that I had different. Here hoping that it will solve my media bridge disconnects.
Thread starter | Title | Forum | Replies | Date |
J | Noob DNS questions | Asuswrt-Merlin | 3 |
Welcome To SNBForums
