I have set up OPENVPN with NordVPN as per attached doc
VPN status on website showing as i have protected status but its leaking DNS when i check DNSleaktest
i have been on with there team and they have checked all merlin settings and we also tried all versions of Accept DNS Configuration but it is not resolving correctly and picking up there backup servers and not the correct routing to the UK side. the same vpn file worked before upgrading.
They are now saying nothing else they can do and to downgrade fw (yes to test)
as part of the debugging i reset factory settings.
current setup is
VPN1 active, (tried relaxed, strict and exclusive) and redirect all (will do policy based when all working)
WAN dns settings as per there docs and showing selected under wan - dns settings
DHCP server settings blank
DNS filter off
Hope links are ok, this is there doc, its for older FW but idea is same
current setup is
DNS filter off
AsusWRT Merlin setup with NordVPN
Fortunately, you can use NordVPN with your Asus router. These instructions will help you set up an OpenVPN connection with NordVPN on your ASUS router flashed with AsusWRT-Merlin firmware. The inst...
support.nordvpn.com
