(Not specifically) VPNMON-R3 1.11 failure domino effect
Okay, I've just realized that the list automation with the servers isn't working at all (TLS error). Unfortunately, it's extremely difficult to access the config, and I can't even get into the server list automation menu because the vpnmon closes, probably crashing. :(
I solved it manually by shutting down the vpnmon, fixing the servers in the GUI, and then starting the vpnmon again. This way, I can access the config because it doesn't start the restarting process, as all the monitored VPN servers are active.
Making sure your VPN slots work individually and can connect without issue is a must-have before starting VPNMON. Also, before entering any kind of server list automation statement, you need to ensure it's pulling back a list of valid IPs. Just run the statement itself in a separate SSH window from a command line to test things out.
When you run VPNMON, immediately before it wants to reset a connection, it shows a 5 second timer to (P)ause the reset. Hitting P will let you into the config/operations menu. Thanks for sharing and letting us know you got everything resolved!
AMEN!
From an SSH prompt, just type "vpnmon-r3 -setup". That should let you right in.
If it's still kicking back that it can't connect and reverts back to the 5 min timer, there's something else going on with WAN/DNS, or connectivity in general. Are you able to reach 8.8.8.8? Have you tried the reboot option yet?
vpnmon-r3 -setup
