NTP not sync in RT68U
I solved the problem.
It was a firmware issue.
The fix was to do a factory reset, then, manually re-enter all settings. (DO NOT upload a saved configuration file.) I took screenshots of everything that had anything different from defaults, but this was still time consuming and a PITA. But it fixed both the "disconnected" problem, and also the NTP problem.
Factory reset fixed it?
I could have told you that! :)
Glad you've got your router in a good/known state again.
Hi All
i've been experiancing this problem since months on my RT-AC68U with merlin 386.13 . I have a huawei usb 4G modem without any cable internet, so I used wan usb as primary and I've disabled dual wan options.
I experianced that the internet is being dropped randomly and I could not figure out why. NTP keeps complaining about unable to sync therefore the date was back to may 5 as it has been told in several topics here
but, then letsencrypt disconnected the internet due to unsync time. And then there is a loop.
If I reboot the router it is holding for the internet connection for a while but then randomly disconnects.
I disabled letsencrypt for now, and for the first time in months it is still online for the next morning.
I'll keep you posted.
Did I miss something in the configuration or is it a bug? What do you think?
What NTP server is configured in Advanced Settings > Administration > System ?
The default is pool.ntp.org and works here.
Turns out the 3G/LTE usb stick breaks connection randomly therefore the NTP cant sync etc etc etc.... I keep trying to identify the issue but no success.
btw I have pool.ntp.org there and it is working fine as long as it is not disconnected
thanks for the reply anyhow
