NTP Time Settings
cory_booth
Hopefully this is the right place to discuss this:
I have a RT-N66U Router running 3.0.0.4.376_1071 firmware.
Never installed anything different than stock (thus far).
The problem I have...
Every time the router reboots and periodically without a reboot - I loose the time.
I have read numerous responses regarding different NTP servers and also the issue with DNS and potentially using a straight IP rather than a DNS name.
Right now I have a straight IP in the NTP time server address.
When I click "Apply" on that page, the time syncs and everything is good - so it works.
But if I reboot - I loose the time again and have to manually click "Apply"
If I change to an alternative - like 0.us.pool.ntp.org its the same thing.
My problem is parental controls fail to work right when time is not sync'd
How can I fix this?
How can I fix this?
I haven't used the N66U in years but when I did I would use the following NTP servers and still do to this day:
time-a.timefreq.bldrdoc.gov
time.nist.gov
The first is the atomic clock ntp server in Boulder, CO. As for the other I am assuming it is based in DC or wherever the Nat'l Institute on Standards and Technology put it.
Hope this helps!
There's a thread around here somewhere discussing an almost identical problem and I believe it was on an RT-N66. I can't find it now. It was active sometime within the last year, and don't know if it was resolved.
Search, search, search...
Sorry I couldn't offer anything more...
