Question - How Does Wireless Log determine Connected time?
Sorry, I don't know anything at all about the new VLAN routers. Maybe brctl show might show something.
Here is brctl show output — i find it strange that br53/br54/br55 bridge names don't match eth0.52/eth0.53/eth0.54 interface names.
brctl show
bridge name    bridge id        STP enabled    interfaces
br0        8000.107c61af7668    no        eth0
                            eth1
                            eth2
                            eth3
                            tap22
                            wds0.0.1.0
                            wds3.0.1.0
                            wl0.0
                            wl1.0
                            wl1.4
                            wl2.0
                            wl3.0
                            wl3.4
br53        8000.927c61af7669    no        eth0.52
                            eth1.52
                            eth2.52
                            eth3.52
                            wds0.0.1.52
                            wds3.0.1.52
                            wl0.52
                            wl1.52
                            wl2.52
                            wl3.1
                            wl3.52
br54        8000.7a7c61af766d    no        eth0.53
                            eth1.53
                            eth2.53
                            eth3.53
                            wds0.0.1.53
                            wds3.0.1.53
                            wl0.1
                            wl0.53
                            wl1.53
                            wl2.53
                            wl3.53
br55        8000.927c61af766a    no        eth0.54
                            eth1.54
                            eth2.54
                            eth3.54
                            wds0.0.1.54
                            wds3.0.1.54
                            wl0.2
                            wl0.54
                            wl1.54
                            wl2.1
                            wl2.54
                            wl3.2
                            wl3.54
VLANs are tags applied to network interfaces. You still need to go with the virtual network interfaces, like wl0.54 in this case.
I am continuing to hit a wall here...
So we were able to find the vlan tags in nvram here:
apg_ifnames=br53 br54 br55
And found these corresponding vlan-tag nvram variables that show all the virtual network interfaces in use
apg_br53_fh_wlifnames=wl0.52 wl1.52 wl2.52 wl3.52
apg_br54_fh_wlifnames=wl0.53 wl1.53 wl2.53 wl3.53
apg_br55_fh_wlifnames=wl0.54 wl1.54 wl2.54 wl3.54
However, if you enumerate any of these "wl0.52", "wl2.53", etc... interfaces with the wl command, they're coming back with:
wl: wl driver adapter not found
@RMerlin, any other thoughts on how to pull wl-related connection data from wireless clients attached to these virtual network interfaces? I appreciate your insight on this...
Dunno, you would have to dig through nvrams. I use a closed source function in libshared (get_apg_vid_by_ifname(char *ifname) ).
I thought I was on the right path when everything started lining up like that... ugh. Will keep searching... thank you!
