Hi
I have ASUS Merlin AC86U 386.11. Entries to static list will not amend nor delete. I have done several hard resets and the 27 entries just keep re-appearing.
I have tried nvram set dhcp_staticlist=""
nvram commit
reboot
Nothing works.
Any advice please.
thanks for that.
I just did a nvram unset dhcp_staticlist and no change. All 27 reservations still there.
this producesCode:rm /jffs/nvram/dhcp_staticlist
Do a hard reset as described here:this produces
admin@ATTIC-ROUTER:/tmp/home/root# rm /jffs/nvram/dhcp_staticlist
rm: can't remove '/jffs/nvram/dhcp_staticlist': No space left on device
As I said in my opening post, I've done that several times.Do a hard reset as described here:
I know you said that. I wanted to confirm that you were using the correct method because a hard reset will erase the contents of /jffs.As I said in my opening post, I've done that several times.
OK thanks I'll try that.I know you said that. I wanted to confirm that you were using the correct method because a hard reset will erase the contents of /jffs.
It ought to work regardless of the firmware version currently installed. But as a last resort you could try installing an older version of the firmware, say 386.9, and then trying the hard reset again.
Ok I loaded 386.9 and did the WPS hard reset. The dhcp range is default and the router IP is default but all 27 assigned IP still exist as well as port forwarding info. Does this mean the router is dead......OK thanks I'll try that.
After you do the hard reset and power on off the router, what is the first screen you see when it’s at the setup stage. Is it asking you to change the default web admin username and password? Whenever I do a hard reset that’s the first screen. A regular gui reset the first screen is picking ssid and password, then comes the screen changing the admin login. Asking this silly question to make sure you’re hard reset is working…..OK stock ASUS, hard reset, and still showing 27 reserved IPs as well as port forwarding info.
Have to go out now but will respond later....
Yes first screen is web admin etc then ssid etc, so yes hard reset.After you do the hard reset and power on off the router, what is the first screen you see when it’s at the setup stage. Is it asking you to change the default web admin username and password? Whenever I do a hard reset that’s the first screen. A regular gui reset the first screen is picking ssid and password, then comes the screen changing the admin login. Asking this silly question to make sure you’re hard reset is working…..
Welcome To SNBForums
