Open VPN Server
Success! Was perusing through the client settings of the OpenVPN client on the phone. There was a section called "Routing" and under that was a checkbox for IPv4 -> Use Default Route (Redirects all traffic through the VPN). It was unchecked,. I checked it and reconnected the VPN. All seems to work as desired.
Thanks for the help!!
Just noticed, in OpenVPN Connect->Settings, there's an IPv6 section where you can select IPv4 only tunnel.
