Open VPN simultaneously VPN Client and Server 384.11_2 AC88U
amplatfus
I recently update to 384.11_2 from 380 and have a strange problem.
I use VPN Server (1,2) and is working. I also use VPN Client (1,2,3,4,5) and is working. But when I activate both I have no internet on VPN Server connected clients and VPN Client (1,2,3,4,5) give no internet to policy list for Client and I cannot conect to Server.
On 380 it worked in same configuration.
I did factory reset before flash 384 and after 384. After I saw this is not working I tried to restore from backu did with 380 on 384 and doing wo it worked. Than I did again factory reset on 384 and no facing the same prblem.
Please advice what do try next or what should I check, or what am I doing wrong.
Thank you so much!
PS: I use only one active connection per VPN Server / VPN Client but I entered (1,2)/ (1,2,3,4,5) in order to avoid confusion.
Edit1: and I have a strage user activity when Client/ Server activated. Please take a look at screenshot.
Thank you. Is not working in my case. Even in Merlin 380 it worked. I have to change the port of VPN.
If you change the port number you will of course need to generate a new .ovpn file and import it into the client device and delete the old profile.
If you are still getting nowhere, there is a lot to be said foe deleting all the OpenVPN profiles etc and starting over again from new. If you’re not familiar with it, sometimes you make a mess of things first time round. Second time you try, you’re already partly experienced and have a better idea of what you’re doing.
